Looking For Advice On These Waste Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2016, 03:29 PM   #1
Rewards Points: 374
Looking for advice on these waste pipes
I'm renovating the bathroom and need some advice on reconfiguring the waste pipes at the point in the picture.
The simplest solution I can see is cutting off the trap and capping the shower waste pipe, then tying the new toilet into the 3" pipe. Despite lacking elegance, is this an acceptable option?
If I did decide to cut this section out and redo it, what would be the best way? Do I still need the old shower vent or will the vent at the beginning of the run suffice?
costgeek is offline   Reply With Quote
Old 05-19-2016, 04:11 PM   #2
Rewards Points: 1,852
Re: Looking for advice on these waste pipes
Need to know what state and city you reside in so we know what code applies.
But what you have leaves me wondering how you plan to vent the shower without using a dry below the floor flat vent that does not meet IPC code.
Old 05-19-2016, 04:13 PM   #3
Rewards Points: 374
Fairfax, VA
Tags
plumbing , pvc , waste pipes
Frozen pipes in an Kitchen & 1/2 bath addition with inaccessible pipes briantye General DIY Discussions 18 01-12-2015 08:46 PM
Insulating attic pipes thew60 Insulation 4 01-10-2014 02:23 PM
copper pipes gt1935 Plumbing 6 12-28-2013 06:21 PM
Did I just ruin my copper pipes with steel wool? ghutch Remodeling 1 10-09-2013 07:02 AM
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
