A LOCK - Outdoor Faucet - Want The Best! - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2015, 12:41 PM   #1
Rewards Points: 34
I recently purchased a condo a block away from the beach in S. Florida.
I'm looking to replace my outdoor faucet with LOCKED faucets & I want the best on the market (Home Depot, Loews or online). Can you recommend what I should get? They can be either a key or combination.
Thanks,
Scott
Scotty13 is offline   Reply With Quote
Old 09-03-2015, 12:45 PM   #2
Rewards Points: 5,348
Why not just turn off the exterior hose bib until you want to use it? Is water theft that prevalent?
Ron
B. Franklin 1759
Old 09-03-2015, 01:02 PM   #3
FIDO...
Rewards Points: 323
This is admittedly a long shot for a FL setup (versus a location up north where winterizing hose bibs is necessary), but does the external faucet happen to have an internal shutoff valve somewhere inside?
If so, that would be an easy "fix" to deter water theft
Cheers, Chris
Chris130 is offline   Reply With Quote
Old 09-03-2015, 01:56 PM   #4
Rewards Points: 777
Remove the handle
ct18 is offline   Reply With Quote
Old 09-03-2015, 02:09 PM   #5
Retired Moderator
Rewards Points: 7,174
keyed hose bib - Google Search
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
jmon (09-04-2015), TheEplumber (09-03-2015)
Old 09-03-2015, 02:11 PM   #6
Retired Moderator
the name is 'keyed hose bib'---lots to pick from---from 'reasonable' to 'Holy Cow'
Old 09-03-2015, 04:04 PM   #7
Rewards Points: 34
@Ron6519 - Itís a VC home and donít have access to valve and the faucet is accessible to other units.
@Chris130 - Iím having one added to my patio. So I would like to install with a lock.
@ct18 - Thatís a good idea.
@ohímike - Thanks for the suggestion an image.
Old 09-03-2015, 04:08 PM   #8
Rewards Points: 34
@oh'mike - Would a standard garden hose hook onto that keyed hose bib?
Old 09-03-2015, 08:48 PM   #9
Retired Moderator
Yes, they are set up for a regular hose----good idea to keep beach goers from washing their feet at your place--and maybe leaving it running.
Old 09-04-2015, 04:37 AM   #10
Rewards Points: 34
@oh'mike - HUGE Help! Thank you, Scott
Old 09-04-2015, 06:44 AM   #11
Rewards Points: 3,130
I've never seen a spigot like the one oh'mike posted a pictue of. All I've ever seen (and I actually had to replace one on our church building) had no handle and a stem that was recessed and oddly shaped. You can't grab it with pliers; the only way to operate the faucet is with a special tool that fits onto the stem. Although you can buy the tool at some big box stores, it'd be highly unlikely any random beachgoer would be carrying one. And that type of spigot is also probably less expensive than one with an actual lock and key (but still not gonna be cheap).
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (09-04-2015)
Old 09-04-2015, 03:44 PM   #12
Retired Moderator
This one has a removable key---Much simpler and less cost than the fancy one pictured above.
Can I install a lock with key on both sides on my Andersen 400 Hinged Patio door mystiky Windows and Doors 10 04-03-2018 01:35 PM
Antique mortise door lock repair (possibly deadbolt problem?) ohman Windows and Doors 14 08-18-2015 09:58 PM
Any reason to lock out heat pump swilk HVAC 9 02-03-2014 06:34 PM
Installing Segal deadbolt lock traghel General DIY Discussions 2 01-03-2014 10:32 AM
key in the lock on the inside and now can't open from outside kwisj Windows and Doors 1 05-18-2012 07:37 AM
