Community Links |
Pictures & Albums |
Members List |
User Tagging Statistics |
Hash Tag Subscriptions |
Search Forums |
Tag Search |
Advanced Search |
Google Search |
Find All Thanked Posts |
Search Blogs |
Tag Search |
Advanced Search |
Go to Page... |
Thread Tools | Display Modes |
#1 |
Rewards Points: 68
![]() Limit flow into dishwasher
I need to reduce the amount of water flowing into my dishwasher. I came to this conclusion based on these observations:
The city, Sunnyvale, CA, has its own water system. There is no pressure regulator outside our house, which is in a subdivision from 1970. The plumbing was replaced with copper long before we moved in, except one section that was still galvanized from the meter to the house. We had that section replaced with 1" copper a few years ago. No, I don't have a pressure meter. The dishwasher is 25 years old, but it's a well-built European model, an Asko, that still works well. I am hoping to get some more years out of it by fixing this overfill problem. I tried to Google 1/4" pressure reducing valve, but came up empty. Any ideas? |
Sponsored Links | |||
Advertisement |
#2 |
retired framer
Rewards Points: 1,182
![]() Re: Limit flow into dishwasher
Do not use flat bottom gables with scissor trusses. |
Advertisement |
#3 |
Rewards Points: 68
Thanks, but I have already checked the drain hose, and my model doesn't overflow to the base pan. It actually drains quickly, it's just that there's too much water.
Advertisement |
#4 |
retired framer
Most have a float that limits the water, it would be in the tub,
huesmann likes this.
#5 |
Rewards Points: 816
If for some reason, your d/w operates by timer and not float, just turn down the flow rate using the knob on the supply valve?
Nealtw likes this.
#6 | |
Rewards Points: 68
![]() Re: Limit flow into dishwasherQuote:
I could turn down the supply valve, but that single valve also supplies the kitchen sink, and I don't want to lose the flow rate to the faucet. I'm going to try my original plan of putting a dent in the copper tubing. I will have to be careful, because I don't want to reduce it too much, so I'll do it in small steps. |
#7 | |
retired framer
#8 | |
Rewards Points: 816
#9 | ||
Rewards Points: 68
The previous owner of the house rotated the sink 45° counter-clockwise when the family room was added, which explains the 1/2" copper pipe. Quote:
![]() Nealtw likes this.
#10 |
Rewards Points: 816
Interesting...I would have thought that a 1/4" line would be self-limiting as far as water flow!
Could you install a needle valve on the horizontal leg of the T? |
The Following User Says Thank You to huesmann For This Useful Post: |
StevenS (11-22-2019)
#11 |
Property Mgt/Maint
Rewards Points: 7,044
Something like this should get you out of trouble
https://www.pexuniverse.com/1-4-od-c...ght-stop-valve Have you checked the whole house water pressure. May be running to high. For about $10 a simple gauge like this can be threaded on to any hose bib for a quick reading. ![]()
[political signature removed] |
#12 |
Rewards Points: 68
Now why didn't I think of that? Thank you very much for that suggestion!
#13 |
Rewards Points: 68
Thanks for another great idea! I've been thinking about checking the pressure, but never got around to buying a gauge.
#14 |
retired framer
Those gauges come with a hose bib fitting, often outside bibs get full pressure so check pressure at the washing machine hose bib.
#15 | ||
Rewards Points: 68
I was advised to install a water pressure reducing value. Is there anything I should know about buying one? Can I just get a standard one from Home Depot? |
Advertisement |
Tags |
dishwasher hookup
Display Modes |
