Leaky Washer Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2015, 08:09 PM   #1
Rewards Points: 2
Leaky Washer Valve
Hello DIY's,
On my 15 year old washer I have slight drip at the washer just under the handle. I've tightened the top but am having a time trying to tighten the base without rotating the valve/pipe itself; I don't want to break it. I'm using a channel lock/pliers and was wondering if it's frozen if I need a plumber or how someone may have been able to replace it without opening up the wall or breaking the pipe. The basic pic sums it up. Any thoughts/suggestions would be appreciated.
Thanks!
DIYROB is offline   Reply With Quote
Old 04-13-2015, 08:18 PM   #2
Rewards Points: 18,974
Looks like that nut just holds on the handle.
Remove the nut and the handle and just snug the packing nut under the handle.
Use a real box end wrench on the nut not plyers.
Old 04-13-2015, 09:02 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 254
Hi DIYROB, Welcome aboard!
It looks like you are connected to CPVC pipe in the box. If so, don't tork much on the valve without good backup on the pipe. The CPVC pipe can't take much twisting.
As Joe said, pull the screw on top and see if there is a packing nut under the handle- snug it up a tad.
Old 04-13-2015, 09:09 PM   #4
And replace those old rubber supply lines with new braided lines asap.
One of the most common insurance claims is from flooding caused by burst washer hoses.
Leaky furnace valve billinak HVAC 9 11-01-2009 07:11 PM
I thought I put it back together properly: leaky shower valve (Matco-Norca) shuuy Plumbing 1 06-18-2009 10:44 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Help with spud washer on toilet flush valve meck23 Plumbing 13 01-21-2008 08:24 AM
