Leaky Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2015, 09:47 AM   #1
Rewards Points: 31
leaky valve?
I have an old PF three-handle shower faucet. It started leaking and I removed the deformed (compressed) washer from the stem end of the cold valve and put on a new one as I have done before. Still drips cold water. When the valve was out I fingered the valve seat and it seemed smooth to me. What's going on? Thanks.
gulleyj is offline   Reply With Quote
Old 08-28-2015, 10:53 AM   #2
Rewards Points: 3,492
You may have an old worn seat and stem. Is it something like the photo. May need a rebuild kit for it. Just a suggestion.
Please wait for the plumbers to respond. Thanks.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
SeniorSitizen (08-28-2015)
Old 08-28-2015, 02:19 PM   #3
Rewards Points: 28
I would replace the seat even it the existing one seem smooth. They are cheep and no reason to get into the faucet again in a few days. If it is still dripping from the spout it may be the washer you put in is to hard to set to the seat. Happens a lot when the washers are old. If it is coming out around the handle the o-rings or packing on the stem may need to be changed.
Happy DIYing.
Blaine125 is offline   Reply With Quote
Old 09-05-2015, 07:52 PM   #4
Rewards Points: 31
Put in new seat. Washer is the same kind I've been using without problems for years. Still leaking from spout, So what's the problem?
Old 09-06-2015, 02:51 AM   #5
Rewards Points: 38
Did you replace both hot and cold?
SHR Plumber is offline   Reply With Quote
Old 09-06-2015, 06:52 AM   #6
Rewards Points: 582
I would do both sides hot and cold...and use beveled washers....also check the shower diverter washer as well..sometimes after showering the water drips from the pipe leading to shower head for a while...then it stops...
The Following User Says Thank You to ben's plumbing For This Useful Post:
jmon (09-06-2015)
Old 09-06-2015, 12:33 PM   #7
Rewards Points: 31
Used bevelled washer. Didn't put new seat on hot side: drip is cold and continual, so not from diverter.
Fixing leaky 1962 main water valve bighak Plumbing 2 02-21-2013 08:15 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Leaky furnace valve billinak HVAC 9 11-01-2009 07:11 PM
I thought I put it back together properly: leaky shower valve (Matco-Norca) shuuy Plumbing 1 06-18-2009 10:44 AM
