Leaky Handle After I Turn Faucet Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2016, 10:27 AM   #1
pb2
Rewards Points: 22
Leaky handle after I turn faucet off
Hi,
I have a Kohler single handle faucet that leaks from the handle AFTER I turn the water off. I replaced the cartridge with a new one, with the hopes that it would fix the problem, but no luck. I've noticed that if I pull the spray head down, it doesn't seem to leak (or at least as much).
It seems to me that there's some pressure buildup in the spray head that is coming back through the handle. I don't know how to fix this though.
Here's the faucet I have.
Here's a picture I took of what's going on:
Any thoughts on what I should do?
Thanks,
PB2
pb2 is offline   Reply With Quote
Old 01-16-2016, 06:20 PM   #2
Rewards Points: 3,476
Turn off water and recheck your work. Remove handle, remove cartridge, check and make sure retaining nut is secure, o-ring didn't crimp, etc. Use some plumbers grease on cartridge. Reinstall, and try again, check for leaks.
jmon is offline   Reply With Quote
Old 01-16-2016, 10:01 PM   #3
pb2
Rewards Points: 22
I'll do that. It does seem like if it was sealed a little better this might not leak. I didn't see an o ring, where would that go? Also, I didn't use plumber's grease. What does that do?
Old 01-17-2016, 09:50 AM   #4
The exploded view (below link) shows the parts better. From kohlers website.
The plumbers grease helps parts go together smoothly and work better. Not really needed, just a suggestion. Sometimes replacement cartridges come with a little packet of silicon grease.
http://www.ereplacementparts.com/koh...76_150589.html
Old 01-17-2016, 10:00 AM   #5
If still no better, you can call or go to kohlers website for assistance. Have your faucets model number. They are a very reputable company and will help you out. They will even send free replacement parts if needed.
It may be something simple you're forgetting or not doing correctly. Hope you get it figured out and up and running correctly soon.
Very nice faucet btw.
Old 01-17-2016, 12:02 PM   #6
pb2
Rewards Points: 22
Thanks. Maybe there was another piece that is missing. I'll take a look at the exploded view and I'll give Kohler a call. Good suggestions!
Here's a video, btw, of what's happening: https://photos.google.com/share/AF1Q...9kQVBIaXZOaVRB
Also, here's a picture of the inside:
The Following User Says Thank You to pb2 For This Useful Post:
jmon (01-17-2016)
Can't get this leaky faucet handle off. Unknown brand. okstate Plumbing 12 12-22-2013 10:01 AM
Replacing outside faucet handle bucksone Plumbing 1 09-27-2012 09:11 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
Quick leaky faucet question JPfixit Plumbing 5 12-09-2008 11:21 AM
Faucet won't turn off etiger Plumbing 1 08-31-2005 02:46 AM
