Leaky Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-06-2015, 06:27 PM   #16
Rewards Points: 6,408
Sorry Joe, but I can't be of further assistance. The valve and associated parts are too much different than I'm familiar with to continue giving advise and I don't want to give incorrect advise. If I had taken it apart I could probably determine the problem but that doesn't help you.
Hopefully someone will be along that's more familiar with your situation.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
joetab24 (10-11-2015)
Old 10-06-2015, 07:06 PM   #17
Rewards Points: 512
No problem. I should have been more precise when removing the pieces.
joetab24 is offline   Reply With Quote
Old 10-10-2015, 09:33 AM   #18
Rewards Points: 512
Can anyone else help? Will some more pics help?
Old 10-10-2015, 10:21 AM   #19
Rewards Points: 512
Here are some more pics.
Note: The leak is fixed. I just can't get the faucet back in place. Didn't pay close enough attention when disassembling. It doesn't seem to me that the faucet is secured to the sink from underneath.
https://drive.google.com/file/d/0B5y...ew?usp=sharing
Old 10-11-2015, 10:53 AM   #20
Rewards Points: 512
Have made some progress. I identified a piece that is broken. It is the metal piece that screws in on the top (see video).
Not 100% sure I have the faucet positioned properly, in terms of the position of the faucet when it turns. I also purchased a basin wrench, though I am still struggling to tighten the nut as securely as it needs to be. Thanks for taking a look.
Old 10-11-2015, 11:58 AM   #21
Rewards Points: 3,436
Took a look at your video. If it were me, I would make the handle swing the other way when it turns on so its not so close to the wall. Nothing wrong with the way you have it. It works.
If you want it to swing the other way, remove and rotate the cartridge 180 degrees. Insert the cartridge back into the valve body. It should now swing the other way. Just a suggestion.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Old 10-11-2015, 12:03 PM   #22
Been following your thread Joe. Glad you finally figured it out and got it working. Nice job.
Old 10-11-2015, 02:29 PM   #23
jmon's reply reminded me of a tip that may be useful to someone albeit it may not be of any help to Joe at this point.
With the valve in the off position and the knob / handle removed, mark the cartridge orientation with a felt pen before removing it. I know on mine, mostly Delta, it keeps me from having to do the 180 degree rotate thing most of the time to allow the handle / knob to operate as it did originally.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
jmon (10-11-2015), joetab24 (10-11-2015)
Old 10-11-2015, 05:03 PM   #24
Rewards Points: 512
I haven't gone to the store to look. Figured I would check here first.
Any idea if this piece is available online:
On the side I was able to fix, this is one piece. So it appears that it broke/I broke it when I was initially removing it.
Old 10-11-2015, 05:33 PM   #25
They're all a little different Joe. Is this a delta faucet? Do you have the model number of the faucet. Sometimes it can be found right on the back of the faucets escutcheon. Sorry if you already posted the information.
Take the parts with you to a local big box, plumbing supply or hardware store and try to match them up. If you can't find it locally, go directly to the manufactures website. Look at the exploded view for your faucet and find the part number(s) you need or ask a customer service rep. to help you find it.
Once you have a the part number(s) you should be able to get it directly from the manufactures website or through amazon.com. Unless of course the faucet is discontinued. Just a suggestion.
Old 10-11-2015, 06:30 PM   #26
Rewards Points: 512
Thanks, jmon!
I actually haven't been able to find a manufacturer listed anywhere. I'll bring the piece to the store and try to match it. Is it called a flange?
Old 10-11-2015, 07:01 PM   #27
I agree, I would call it a flange. Does the other piece have threads? Then it's some kind of locking nut maybe? You're definitely going to need that. Or is it some sort of friction washer. You might get lucky finding them separate. If no luck at the big box or hardware stores go to a local plumbing supply store they may be able to help.
You may have to buy a faucet handle rebuild kit just to get those 2 pieces you need. Idk.
Your bathroom faucet reminds me of a price phister.
Old 10-11-2015, 07:22 PM   #28
Edit: meant to say you may need to buy mounting kit for a widespread faucet instead of faucet handle rebuild kit.
One piece looks like a flange and the other, if threaded, looks like some sort of mounting nut.
I agree with you, they both look pretty banged up and will need replacement. Hope you can find them somewhere locally.
Old 10-11-2015, 10:11 PM   #29
Rewards Points: 1,508
It may be called escuchon or finish escuchon/plate. It is a cover only which is also covered by the round body with the handle, so you may get by with attaching it with silicon. If you go, may help by taking the whole assembly with you-the stem where it screwed on.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
jmon (10-12-2015)
Old 10-12-2015, 08:34 PM   #30
Rewards Points: 512
So....kicking myself because this should have been an easy fix. Though when you try something you have never done before, I guess this is bound to happen.
Tried to find a replacement for the piece that I broke. No luck at the big box store. And I can't find any name on the faucet to try to find replacement parts.
I decided tonight to buy another faucet. It's similar to the one I have: http://www.ebay.com/itm/271911009463. Got it for $56.
Since this is a pedestal sink it seems I am going to have to disassemble it in order to install the new faucet. It is really difficult to get to anything with the sink in place.
I see I am going to have to remove these two nuts. Would you just use a ratchet? When I tried to use the ratchet set that I have, I couldn't get in there. The 1/2" didn't fit. I think its because the bolt is getting in the way.
Some pics
leaky shower faucet diy'er on LI Plumbing 3 09-03-2012 05:33 AM
Double Basin Concrete Sink leaky faucet newoldhouse Plumbing 3 05-14-2012 10:25 PM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
Quick leaky faucet question JPfixit Plumbing 5 12-09-2008 11:21 AM
