Leaking Outdoor Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2016, 04:28 PM   #1
Rewards Points: 398
A few months ago I had our backyard anti-frost faucet replaced. Came home from work today to the sound of running water. I guess one of the kids left the faucet turned on with the splitter valves off from the weekend and maybe it blew a gasket at the top? Either that or it was coincidental.
I unscrewed the top cap as shown - is this serviceable or do I need a whole new faucet? If so, how do I take it apart past here? I tried prying the white piece up with a flathead but it didn't budge.
No water leaks with the valve off.
Leaking outdoor faucet-image-254565849.jpg   Leaking outdoor faucet-image-2681280769.jpg
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 06-14-2016, 05:22 PM   #2
Rewards Points: 398
Disregard - I was able to fix it. Just needed channel locks to unscrew the plastic cap and reset the gasket. No more leaks.
The Following User Says Thank You to adgjqetuo For This Useful Post:
jmon (06-14-2016)
Old 06-14-2016, 05:31 PM   #3
Retired Moderator
Rewards Points: 7,174
Re: Leaking outdoor faucet
Good to hear ---
to answer your first question--(other members have this issue)-
Yes---the cap hides a plastic valve assembly---replacement is as simple as removing the old one and popping in a new one---last time I needed one it cost less than $5.00
Old 06-15-2016, 10:43 AM   #4
First Home N00b
Rewards Points: 202
It's located right next to the sillcocks in the plumbing aisle in most box stores.
95PGTTech is offline   Reply With Quote
Bathroom Sink Leaking DoubleHumbucker Plumbing 17 11-08-2015 11:36 PM
Leaking Milgard vinyl windows (occasionally) lazzlazz Windows and Doors 14 08-08-2015 02:40 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
