Leak When Shower Turned On Near Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2015, 11:19 AM   #1
Rewards Points: 4
Leak when shower turned on near spout
When I turn on the shower I am noticing a leak right where the spout meets the tile in my shower. I have a single lever to turn on the water.
Any idea on what could be causing this?
Leak when shower turned on near spout-img_1427.png   Leak when shower turned on near spout-img_1426.jpg   Leak when shower turned on near spout-img_1425.jpg
supersales5 is offline   Reply With Quote
Old 08-27-2015, 11:25 AM   #2
Rewards Points: 242
Considering your rough in is something similar to this I would think something is not tight or soldered correctly. Is this a new install? iS there an access panel somewhere to look and see whats going on in the plumbing wall?
collegetry is offline   Reply With Quote
Old 08-27-2015, 11:58 AM   #3
Rewards Points: 4
There is no access panel and there is all tile work done. This bathroom has been around for about 10 years
Old 08-27-2015, 12:23 PM   #4
Rewards Points: 3,420
Water leaked out and ran down the outside of the middle pipe (behind the tiles) and some came out where the lower end of the middle pipe came out to the tub spout.
The purpose of the little hole in the bottom of the tub spout is to let out any water that might get trapped between the spout and the wall (if the spout were not caulked all the way around) rather than let the water accumulate back there with some going back into the wall.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 08-27-2015, 12:28 PM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
Most likely, it is leaking where the nipple in Collegetry's photo connects to the tub spout. Try to screw off the spout, retape the nipple with teflon tape and see if that does not resolve your issue. Sometimes the spouts are tightened too much and can cause a small crack where it attaches to the nipple. If so you will need to replace the spout. While you have the spout off, make sure the tile hole around the nipple is sealed with silicone. This will prevent water from backing into the wall if this should happen again in the future.
Man of many hats
wrangler is offline   Reply With Quote
Shower leak, now pressure issues (Delta monitor) jlup Plumbing 4 05-06-2013 10:09 PM
Shower leak - testing question booksat Plumbing 4 05-02-2013 04:04 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
