Leak Monitor - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2016, 08:08 AM   #1
Rewards Points: 5,590
Leak Monitor
Is there a leak monitor available, similar to this, that will notify via phone ?
Old 03-04-2016, 08:15 AM   #2
SHEPLMBR's Avatar
Rewards Points: 178
http://www.floodguards.com/commercial_flood_alarms.aspx
SHEPLMBR is offline   Reply With Quote
The Following User Says Thank You to SHEPLMBR For This Useful Post:
SeniorSitizen (03-04-2016)
Old 03-04-2016, 11:05 PM   #3
Rewards Points: 102
I have one of these tied into the water supply to the house. I coupled it with these and via zwave, if there is a leak it shuts off the water supply and emails me. Seems a lot cheaper than the floodguards system.
Tally Wacher is offline   Reply With Quote
Delta Monitor bath faucet leak Zamboknee Plumbing 4 10-26-2015 01:40 PM
Serious slab leak - need advice John972- Plumbing 23 01-17-2014 06:43 PM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-17-2012 11:07 PM
leak in cement tile roof virgo822 Roofing/Siding 2 07-23-2011 05:29 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
