Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2015, 08:36 PM   #1
Rewards Points: 109
Leak
My WH is leaking thru the top element cover...it seems like it's coming from under the foam toward the top. Could it be coming from the anode rod since there is no access to see the anode rod?
Tek1 is offline   Reply With Quote
Old 12-12-2015, 08:50 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 804
Time for a new WH
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Tek1 (12-13-2015)
Old 12-12-2015, 08:53 PM   #3
Rewards Points: 3,220
As suggested, it may be time for a new one. Can you please post a couple pictures of the leak. Thanks.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Tek1 (12-13-2015)
Old 12-12-2015, 10:21 PM   #4
Rewards Points: 1,956
Keep an eye on that bad boy, you're on borrowed time. See the thread on water alarms.
ChuckF. is offline   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
Tek1 (12-13-2015)
Old 12-13-2015, 09:00 AM   #5
Rewards Points: 3,286
You can dig away at the insulating foam here and there (starting at openings such as the anode cover) to try to find the leak.
Usually this is too time consuming and troublesome and when you do find the leak that is usually unrepairable so you might as well start shopping for a new water heater now.
If you do dig away at the foam you might hit a nearly rusted through patch that is the source of the leak, and make the leak suddenly much bigger.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
The Following User Says Thank You to AllanJ For This Useful Post:
Tek1 (12-13-2015)
Old 12-13-2015, 09:42 AM   #6
Rewards Points: 109
I was thinking replacement as well but wanted to check with the pros in case it was repairable.
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 10:15 AM
HVAC leak for Freon leak spellow HVAC 6 03-11-2012 07:49 AM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-17-2012 11:07 PM
Furnace exhaust stack related leak Michael Ku HVAC 14 12-10-2011 07:27 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
