Layout OK? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2015, 03:12 PM   #1
Rewards Points: 117
Layout OK?
Does this plan look OK?
I'm using an Up-flush system in my basement because my sewer line exits the basement about 24" above the floor.
tommyxv is offline   Reply With Quote
Old 06-03-2015, 03:57 PM   #2
Rewards Points: 1,952
What lay out?
Old 06-03-2015, 04:15 PM   #3
Rewards Points: 117
Originally Posted by Ghostmaker View Post
What lay out?
Ahh.. this one.
The shower base has a 2" trap and is about 5 ft from the pump. The pump will site behind the wall where the first metal stud is in the pic.
Old 06-03-2015, 05:26 PM   #4
Is the red lines the vent. If so its good as long as shower trap is less then 8 foot away.
You will need a 4 inch drain to tie sump into.
The Following User Says Thank You to Ghostmaker For This Useful Post:
tommyxv (06-03-2015)
Old 06-03-2015, 06:36 PM   #5
Rewards Points: 117
Yes, the red is the vent. Shower trap will be no more than 5 ft from the pump.
Thanks!
Need Help on Well Pressure Tank Layout osubuckeye88 Plumbing 16 02-04-2014 06:02 AM
Kitchen/Dining Room Layout JRDepew Remodeling 2 01-23-2014 12:04 PM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
