Laundry Tub Drain Height, Too High? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2016, 02:16 PM   #1
Rewards Points: 28
Laundry tub drain height, too high?
Hi, I am trying to plan out how to add a drain for a washer and laundry tub (sink). However, since the run off 4" pipe is a little off the ground the rough in for the sink is coming at around 24.5", so roughly 25" when accounting for the pitch. Is this doable? Maybe lift the sink up off the ground heigher? Thanks!
Diagram
asat is offline   Reply With Quote
Old 03-18-2016, 03:50 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Re: Laundry tub drain height, too high?
raise the sink..no problem
WhatRnsdownhill is offline   Reply With Quote
Old 03-18-2016, 07:48 PM   #3
Retired Moderator
Rewards Points: 7,174
An AAV may not work well for a washing machine drain----because the washer discharges at a high volume.
Here that would not meet code--but might in your area---
asat (03-18-2016)
Old 03-18-2016, 08:04 PM   #4
Retired Moderator
Old 03-18-2016, 08:43 PM   #5
Rewards Points: 198
Can you post a photo? It would be helpful to understand your options.
srloren is offline   Reply With Quote
Old 03-18-2016, 08:51 PM   #6
Diagram
how high is the house trap or sewer pipe going out the wall?
Old 03-18-2016, 09:23 PM   #7
Rewards Points: 1,852
Just build a platform for the Laundry tray or get a wall hung model. An AAV would get you turned down here.
The Following User Says Thank You to Ghostmaker For This Useful Post:
asat (03-18-2016)
Old 03-18-2016, 10:04 PM   #8
Rewards Points: 28
From what i was able to get from product info:
http://www.oatey.com/doc/aavtrifoldlcs420c101812lr.pdf
20 DFUs is no way not enough for a washing machine(3 DFUs).
Old 03-18-2016, 10:06 PM   #9
Rewards Points: 28
I don't know, the 4" CI pipe just goes under the basement. I dont really see the house trap. 4" just covers 2 walls and then goes under at the end of 2nd wall.
Old 03-18-2016, 10:09 PM   #10
Rewards Points: 28
Agreed. I am not fond of using AAV but proper venting isn't an option. Previous owners just used a laundry sink that was not vented and with an S trap.
Old 03-19-2016, 05:31 AM   #11
if the sewer main goes under the floor, there is no reason to be able to lower the whole main to rough in the sink at proper height..
Shower Drain min height? BNR34RB26DETT Plumbing 2 03-19-2015 06:36 PM
laundry tub drain gt1935 Plumbing 5 06-22-2014 10:37 AM
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
Drain too high! sillyboy22 Plumbing 1 11-17-2009 05:37 AM
drain freezing from high efficeincy furnance brokenknee Plumbing 4 12-21-2008 08:26 PM
