Laundry Sink Pump Replace & Gurgle Fix - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2016, 09:36 AM   #1
Rewards Points: 2
Hi,
I was wondering if anyone can give me some tips or at least tell me what they think of my plan.
At my house we have a laundry sink pump in the basement since the sink is lower than the drain pipe. The drain pipe that feeds into, comes almost right off of the kitchen sink.
Basically every time the laundry sink pump finishes pumping, the kitchen sink gurgles pretty loud.
Now the pump went bad and needs to be replaced, since I'm already there.. I thought I could maybe fix the gurgle as well.
So my questions are:
1. What pump would you recommend? I was going to get the "Zoeller 105-0001 Laundry Pump Package"
2. What do you think of me installing the pump with a check valve coming out of it, then installing a check valve on the drain pipe at some point after the kitchen sink, but before the point that the laundry sink pump connects. (the person who installed the laundry sink pump, put the pipe coming from it directly into the drain pipe at a 90 degree angle instead of a 45).
Thanks in advance!
willmatei is offline   Reply With Quote
Old 08-24-2016, 04:19 PM   #2
Rewards Points: 1,866
Re: Laundry Sink Pump Replace & Gurgle Fix
The laundry pump need to tie into a 3 inch or larger pipe. Apparently your kitchen has no vent that is why you get the fun gurgling.
Old 08-25-2016, 06:32 AM   #3
Rewards Points: 18
I am not a plumber but I would be cautious about installing a check valve on the kitchen sink drain line. It might make snaking that line very difficult.
I have a similar setup. My washer drains into a laundry tub which then drains into a sump pit. From there a sump pump pumps it up anout 5 feet and it ties into the main drain (comes in on a 45 degree angle). My check valve for the pump is very close to where the pipe from the pump exits the pit. If i am in the kitchen and the pump goes on, i can hear the water, but no gurgling. Are you sure that you are hearing gurgling? Maybe the real plumbers can suggest something, but what about a "cheater vent" which you install under the sink and it takes air from the cabinet space to vent the plumbing.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Looking for recommendations on updating laundry sink faucet Eagle One Plumbing 15 10-15-2013 05:13 AM
Splice or replace entire wire? Septic Pump bsmith6356 Electrical 5 03-18-2013 06:44 PM
Geothermal heat pump using pool as heat sink mnschu HVAC 9 05-17-2012 08:10 PM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
Direct mount sink pump recommendation kornfein Plumbing 0 04-29-2010 11:49 AM
