Laundry Drain Overflow - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2015, 04:34 PM   #1
Rewards Points: 16
Laundry drain overflow
Hello,
I have a situation where water can overflow from the washing machine drain pipe when the kitchen sink above it drains. This does not happen during normal use of the kitchen sink, but if both bowls are filled and then drained all at once, the water pops up out of the washing machine drain. I've attached a picture, hopefully, that shows the kitchen sink coming down from above, and the washing machine drain ties into it, and they both run straight down. Thanks for any suggestions.
frylock11 is offline   Reply With Quote
Old 11-09-2015, 04:49 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,632
The pipes are coming out of the wall instead of the floor. Turn your picture right side up.
Seriously I see several problems here.
1. There is no trap for the washer.
2. The metal pipe looks like it might be too small. The abs pipe is being reduced sown in size.
3. If the problem never existed before, then the problem is likely a blockage In the metal section of piping.
Old 11-09-2015, 05:19 PM   #3
Rewards Points: 1,856
You must get some awesome smells out of that washer drain... Not to mention a total lack of a vent.
Old 11-09-2015, 05:21 PM   #4
Trucon01's Avatar
Rewards Points: 510
Wow. Yea. Im with joed. Also, you have a pvc couple joining 2 pieces of abs. Probably glued, which isnt good. You also have some sort of couple between copper and abs at the bottom which i dont recognize. Lots of issues man
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 11-09-2015, 05:33 PM   #5
Rewards Points: 582
did someone say code violation
Old 11-09-2015, 05:36 PM   #6
Trucon01's Avatar
Rewards Points: 510
Good thing the line is blocked or it would smell wonderful down there
Old 11-09-2015, 05:55 PM   #7
Rewards Points: 16
The drain has been set up this way for the past 9 years, and that's how it was when we bought the house. I never noticed sewer gas coming from there. We're selling it now, and that's where the issue was brought to our attention, from the home inspection. It wasn't an issue draining under normal use, just when the upstairs sinks were filled up.
Would adding a trap help with the issue I'm having? Would adding a vent help with the issue or do I need a taller stand pipe for the washing machine drain?
Old 11-09-2015, 06:21 PM   #8
Super Moderator
joed's Avatar
I don't think adding a trap will help but it should be done.
A vent might help. It depends on what the actual problem is.
Old 11-09-2015, 06:25 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,.... It's ventin' through the sinks above now,....
Donno 'bout code, but, Ya, a vent will help the flow, 'n a trap will stop the sewer gases,....
Where does the metal pipe go,..??
Bondo is online now   Reply With Quote
Old 11-09-2015, 06:42 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 168
Have you discussed a compromise with the prospective buyer or do you want it fixed properly?
Old 11-09-2015, 06:59 PM   #11
Rewards Points: 16
The copper pipe goes into the basement floor, where I assume it joins up with the toilet and shower drain somewhere underground. I don't plan on digging up the basement floor to run all new drain pipe if it needs to be a little larger, but would install a vent and trap if required. The main issue raised during the inspection was the sinks backing up into the drain when filled up and drained, so that is my main concern.
Old 11-09-2015, 07:35 PM   #12
Rewards Points: 3,220
That's up to you to have it fixed properly.
Whatever you decide to do, I would start by snaking the line first. As suggested, may just be a blockage somewhere. Kitchen sink drains are notorious for blockages. I'm guessing that metal pipe is partially clogged.
Remove trap in sink and snake from there, make sure that line is clear. Then snake the washing machine drain line, make sure that's clear. See if that helps. Just a suggestion.
jmon is offline   Reply With Quote
Old 11-09-2015, 07:59 PM   #13
Rewards Points: 114
Wow. . .This is all sorts of bad
The first problem is that the pipe reduces in size basically acting as a funnel, under full load if it cant clear it fast enough its going to find a different route.
It needs to be redone professionally, but that involves some major rework.
What you could do, is have the drain cleaned and get rid of any corrosion buildup that might be causing food debris to get caught and over time restricting more of the flow.
Second is to extend the laundry pipe horizontally as long as the code permits before needing to be separately vented, add a trap and make the vertical distance correctly for the laundry. This was if it backs up with may not make it all the way to the top of the laundry pipe and overflow.
Again this is a diy fix, and i suggest having it fixed properly.
Good Luck!
Chrisathome is offline   Reply With Quote
Old 11-09-2015, 08:05 PM   #14
Just hope they don't have a real plumbing inspection.... I got a bad feeling.
Old 11-09-2015, 08:55 PM   #15
Rewards Points: 127
If I were buying this, I would say this failed the inspection contingency, get my earnest money back and walk. Tip of the iceberg I fear.
jimn01 is offline   Reply With Quote
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
Floor drain for 2nd floor laundry TomU Plumbing 3 10-22-2011 08:35 PM
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Vent requirement for laundry washer drain pipe WaldenL Plumbing 9 01-12-2009 07:11 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 04:31 PM
