Large Bathtub Spout Gap Fix - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Yodaman
Old 12-10-2016, 07:21 PM   #1
Rewards Points: 46
Large bathtub spout gap fix
Hi All,
A couple of days ago, I noticed a fairly large gap between the bathtub spout and the wall. See attached picture.
What could have caused it? A few weeks ago, I did increase the hot water temp since winter is coming, but I also did that last year.
So I wonder what could have caused it, and I believe the fix would be to cut that portion of the pipe?
SpaceTime is offline   Reply With Quote
Old 12-10-2016, 07:54 PM   #2
Property Mgt/Maint
Rewards Points: 8,184
Re: Large bathtub spout gap fix
Adjusting the water temp likely had no influence on your divirter pulling out.
Look underneath it you might see a slot and a set screw that holds the spout in place.
Loosen, push back in place, retighten set screw.
SHR Plumber likes this.
Yodaman is offline   Reply With Quote
Bathtub leaks when shower turned on smo1898 Plumbing 6 01-27-2014 06:26 PM
Should I change my bathroom "Pinky" bathtub? ChicityChicity Kitchen & Bath Remodeling 3 08-03-2013 11:20 PM
Removal of Tub Spout Remski Plumbing 2 09-11-2012 11:09 AM
where do I set the black o- ring on the tub spout? or the threaded copper pipe? radioflyer77 Plumbing 1 07-05-2012 09:23 PM
BathTub Spout issues prosenba Plumbing 2 12-07-2010 09:38 PM
