Lack Of Hot Water Flow At One Fixture - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2015, 12:57 PM   #16
Rewards Points: 58
No tempering valve.
We are having the same issue in out other bathtub. It's just the two of us, so we hardly ever use other other tub and only noticed our whirlpool tub. I started checking it more often, and it's essentially the same story - Max sustained hot water flow is under 3gpm as well.
apewrangler is offline   Reply With Quote
Low water flow, new PRV, 90psi static GEAF Plumbing 5 05-31-2013 11:56 PM
Can water hammers stop water flow? rj7106 Plumbing 4 12-04-2011 10:39 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
