Kohler Wellworth- Bowl Won't Fill Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2017, 04:58 PM   #1
sweaty
Rewards Points: 332
My Kohler Wellworth toilet flushes well, but fills up slowly and the bowl only reaches a low level. What could be wrong?
On another toilet (same kind), the plastic tube in the tank often detaches, allowing the bowl to fill incompletely. Should I attach it with painter's tape or something like that?
sweaty is offline   Reply With Quote
Old 09-04-2017, 05:07 PM   #2
Rewards Points: 1,251
Re: Kohler Wellworth- Bowl Won't Fill Up
I have 5 Kohler toilets with the canister flush mechanism. They are 8 years old and have been nothing but problems. They stick open constantly and the rings don't last long. The chains get caught and they twist and won't close.
You can't replace them with anything but kohler parts because they are an oddball size.
What may be happening with yours is the rubber ring on the bottom of the canister may have come off or is just bad. Home depot carries them in the store. Kohler has a video on how to replace them. You have to turn the center piece which allows you to get to the ring to replace it.
As for the tube, it should friction fit. You may need a new tube or you might get away with trimming a 1/2" off and seeing if it will stay.
KHouse75 is offline   Reply With Quote
Help!!! Replace fill valve in bathroom toilet problem tman1978 Plumbing 1 04-18-2016 11:28 PM
Metal box fill volume questions TwistedJoist Electrical 11 02-04-2016 02:49 PM
Defective Gerber Avalanche toilet bowl? arandles Plumbing 1 01-26-2013 05:25 PM
To fill, or not to fill? IRuehl Landscaping & Lawn Care 7 08-27-2011 04:30 PM
Toilet Flushing ? Piney Plumbing 5 10-20-2007 01:56 PM
