Kohler Valve & White Tube - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By CaptTom
  • 1 Post By DR P
  • 1 Post By ZTMAN
Old 02-16-2018, 08:36 AM   #1
Rewards Points: 556
Kohler valve & white tube
Ghost flushing. As suggested here I put food dye in tank an 3 hrs later it leaked into bowl. Watched Utube and see that Kohler has a ring gasket so hope it gies well. I'll buy the yellow ring. I've replaced the other kind of flapper.
While I'm going to the store wanted to see if I need to buy anything else. Sometimes it doesn't sound right when flushing. I take lid off and that white tube that delivers water has popped out of the canister. I shove it into the hole an its stays for a week. We have bad water. This happens in both 5 yo toilets.
(Similiar toilet photo)
Startingover is online now   Reply With Quote
Old 02-16-2018, 09:07 AM   #2
Rewards Points: 556
Re: Kohler valve & white tube
First problem. Any hints?
Can't get canister out. Tried turning it left a little an it wont turn. When I force it I start to hear a cracking noise
Old 02-16-2018, 09:43 AM   #3
Rewards Points: 2,908
You might have to remove the tank. Usually two bolts will do it. Most repair kits come with new bolts and rubber gaskets for this purpose.
Startingover likes this.
CaptTom is online now   Reply With Quote
The Following User Says Thank You to CaptTom For This Useful Post:
Startingover (02-16-2018)
Old 02-16-2018, 10:26 AM   #4
Rewards Points: 556
I don't think I can remove tank. The other bathroom is across the house. I'll just switch bedrooms.
I don't have any spare parts.
Old 02-17-2018, 04:11 AM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
you have to push down with constant force on canister while turning left...
but sometimes they do break... replacement parts are found @ H/Depot
Place a little silicone grease on end of piston so next time it may come apart easier...
Edit: you may need new tube & or replacement piston if tube will not stay
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
Startingover (02-17-2018)
Old 02-17-2018, 06:18 AM   #6
ZTMAN's Avatar
Rewards Points: 628
I know what you mean with the fill tube(white). When the toilet flushes, that outside canister raises and knocks the white tube off. Happened to our toilets about once a month.
I tried two remedies, in one toilet a small bead of silicone caulk where tube connects, and in another toilet a candy cane wrap of duct tape. Duct tape works best. Put it on a few months ago and has not happened since. Only need about 1/4 inch strip.
Kohler has a bad design with this model toilet IMO
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
Old 02-17-2018, 05:02 PM   #7
Rewards Points: 556
Gentlemen, thank you.
Success. I used more force and that worked. I figured I didn't have anything to lose. The rubber ring was really gummy. It was tedious putting canister back on as it was hard to line up. I wish I'd known and wouldn't have bought this model. I checked my daughters 3 AS today an they have the normal flappers. When I was property manager I changed flappers when my maintenance men were off. Easier than convincing tenants to wait.
I bought these models cause the lid design was attractive. Never again.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Kohler Tub/Shower Valve Rough In Docfletcher Plumbing 8 03-01-2013 02:09 PM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Kohler toilet flush valve yarp1 Plumbing 2 04-01-2010 08:59 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
