Kohler Shower Handle That Destroyed My Kitchen Ceiling - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By bensplumbing
Old 05-04-2017, 07:25 PM   #1
Rewards Points: 198
Angry
Kohler shower handle that destroyed my kitchen ceiling
A few days ago my kitchen ceiling buckled after a joist cavity let loose a few gallons of water. I won't bore you with the details of how long it took to figure out the problem, but ultimately it ended up being this:
About 20 months ago I had a new shower put in. I discovered that if the cylinder between the handle and the escutcheon (collar?) is slightly loosened, maybe a 1/8 turn counter-clockwise, a river of water goes down the back of the backerboard, and finds its way to my kitchen ceiling.
I assume a slightly loosened trim piece like the collar shouldn't result in water shooting down my interior walls, is that a valid assumption? Should I bring the original plumber back in and have a conversation with him? Is this something I should bring up to Kohler, or is it an install issue?
From what I've briefly read online it looks like maybe the plumber didn't have enough of the neck to bite onto. Is this something that can get fixed with minimal heartache? I do have access from the rear of the unit if necessary.
Thanks for any insight!
MoreCowbell70 is offline   Reply With Quote
Old 05-05-2017, 05:35 AM   #2
Rewards Points: 898
Re: Kohler shower handle that destroyed my kitchen ceiling
Sounds like a bad install. Call your plumber and use his insurance to cover the damage.
BIG Johnson is offline   Reply With Quote
Old 05-05-2017, 06:14 AM   #3
Property Mgt/Maint
Rewards Points: 8,202
Looks like the trims extend too far from the wall, meaning the valve(s) is too close to the wall. With rear access, the valve(s) could possibly be pulled back in a bit. This will put more of the trim in the escusheon. There is a dimension the mfg recommends for this placement that came with the valve install instructions.
Secondly, premium high end hardware generally has built in O-rings and seals to prevent water leaking behind the walls. Personally, I also, always seal the edges with a small bead of clear silicone. A small bead around the outside of the escutcheon, and a small bead between the trim and hole of the escutcheon. The inner bead would have also likely prevented the trim from backing out.
If you do this your self, when caulking, only go around the top 3/4 of the circle. Or from about 8 o'clock to 4 o'clock on the dial. Leaving a small unsealed area at the bottom allows any water that may get in a route to drain back out.
Good luck and I would most definitely be calling the plumber back.
Yodaman is offline   Reply With Quote
Old 05-05-2017, 05:40 PM   #4
Rewards Points: 38
After 20 months Kohler probably won't do a thing except tell you it was installed wrong... I would call the original plumber and discuss it with him...again 20 months ...but if he realized he missed the install an has integrity about his business he may work with you to correct the problem.... It's worth a try...good luck. Ben
BlackTiger likes this.
bensplumbing is offline   Reply With Quote
Old 10-12-2017, 07:06 PM   #5
Rewards Points: 198
Just an update for anyone that remembers this situation - Kohler finally stepped up and covered all the damage.
Old 10-12-2017, 07:18 PM   #6
retired framer
Rewards Points: 15,596
Good for you.
Nealtw is offline   Reply With Quote
bathroom fan and shower light in vaulted ceiling Duane D Electrical 4 01-05-2015 11:01 AM
Need help framing ceiling of shower for tile, ATYPICAL STYLE ChrisDIY Tiling, ceramics, marble 20 03-06-2013 05:09 AM
custom tile shower ceiling maljeff Drywall & Plaster 1 08-21-2012 10:07 AM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Kohler single handle shower randy717r Plumbing 1 03-29-2008 11:35 AM
