Knocking Sound From The Thermal Bypass Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2018, 08:24 PM   #1
Rewards Points: 40
Send a message via AIM to HannesAlven
Knocking sound from the thermal bypass valve
I recently installed a tankless water heater with a recirculation pump. As part of the recirculation feature, I installed the thermal bypass valve (aka sensor valve by Watts) under the sink at the farthest bathroom away (also most frequently used) from the water heater. The valve connects the hot and the cold water inlets. When the recirculation pump is off, I get some light hammering sounds from the bypass valve when I turn the cold or hot water taps off. How can I get rid of this problem? This problem goes away when the pump is turned on. And also I didn't have this problem before I installed this bypass valve.
I have tried changing the bypass valve, using hammer arresters (putting them near the shutoff valves or near the tap), and lowering the water flow with a new aerator. They helped only slightly.
There's a spring inside the bypass valve and I suspect it is being opened and closed inadvertently when the water pressure increased momentarily due to the hammering.
Any help would be greatly appreciated!
HannesAlven is offline   Reply With Quote
Old 02-19-2018, 08:40 AM   #2
Rewards Points: 3,496
Re: Knocking sound from the thermal bypass valve
Welcome to the forums hannes.
In the instruction manual for water heater, does it recommend it or is it optional?
If it's optional, leave it off. As you stated, the hammering started happening when you installed it.
The plumbers will be along with more advice shortly.
jmon is online now   Reply With Quote
Old 02-19-2018, 10:22 AM   #3
Rewards Points: 40
Thanks! It's required according to the instruction manual.
Old 02-19-2018, 12:14 PM   #4
Rewards Points: 80
I've never used this type of setup. Usually places with recirc pumps have a dedicated recirc loop. From reading the instruction manual, I don't think there's much you can do.
Cheers!
supers05 is offline   Reply With Quote
Old 02-19-2018, 12:24 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 290
What is the recirc model # and type of heater? Describe your system better, please
Old 02-19-2018, 02:56 PM   #6
Rewards Points: 40
I have a Rinnai RUR98iN tankless water heater. The recirculation pump is inside the unit (I didn't buy it separately). It's installed in the garage. I don't have a dedicated return line for the hot water so the cold water line is used for recirculation. The thermal bypass valve connects the hot and the cold line together to complete the recirculation loop. The bypass valve is installed under the sink upstairs in the bathroom farthest away from the water heater. The bypass valve is normally open and it closes when the water reaches above 98F.
Old 02-19-2018, 03:00 PM   #7
Rewards Points: 40
I have talked to a plumber and I was told to install a pressure regulator to reduce the pressure to 55 psi (I don't have one). I am reluctant to spend more to do that because I am skeptical that it would fix the problem. My water pressure right now is at 70 psi.
Old 02-21-2018, 04:14 PM   #8
Peace be with you
DR P's Avatar
Rewards Points: 1,860
when the pump is not running...
1. Close the cold water stop valve below the sink with crossover.
2. Open the cold water side of faucet.
3. Water should still slowly flow from the cold outlet side.
This flow should gradually decrease to a trickle of water until finally
no water is coming from the faucet once hot water reaches the crossover valve.
If flow does not stop when water is hot, the crossover is defective.
once the hot water reaches crossover see if it continues to make sounds...
be sure to open back the cold stop valve below sink... and check cold side
Is the crossover valve secured with the ears and screws provided?
Lastly, close the hot stop valve & open the hot side of the faucet...
there should be no flow if internal check valve is operating correctly...
if flow or noises occur, the crossover is likely defective.
if all the above checks out then I agree that your
noise problem may be from too high a static pressure.
Edit: noise could also be coming from an internal check at pump
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
HannesAlven (02-21-2018)
Old 02-22-2018, 12:38 PM   #9
Rewards Points: 40
Yes, I did this and the cold water from the tap stopped almost immediately.
There are no hammering sounds with the above experiment. Yes, I checked and the crossover valve is secured.
Yes, I did this and the hot water from the tap stopped almost immediately. There were no hammering sounds.
Peace
When the recirculation has stopped running for a while (>15min, not quite sure), the hammering sound comes back. It seems like the hammering sound comes back when the hot water in the pipe has cooled down past 98F and the crossover valve opened up. When recirculation is running, there's no hammering sound.
I may just live with this since it's not a big problem. Thanks for the help!
Knocking sound when people walk by my bedroom dtran Flooring 1 01-16-2009 02:27 PM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 01:51 AM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
