Kitchen Sink With Wastebasket Drawer Below. Need Special Drain To Clear. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2015, 07:11 AM   #1
Rewards Points: 434
Kitchen sink with wastebasket drawer below. Need special drain to clear.
Every ikea sink I've ever purchased comes with one of these drains. They allow you to use the space below the sink by installing this adjustable, near horizontal drain pipe that moves the trap to the back of the cabinet.
I need one for my non ikea (Kohler) kitchen sink. Do local hardware or big box stores carry these? What are they called?
vestaviascott is offline   Reply With Quote
Old 08-02-2015, 08:59 AM   #2
Rewards Points: 2,244
You are probably not going to find anything like that drain kit in any big box or local plumbing supply stores and even if you did it may not work with your non ikea kohler sink.
That drain kit is specially designed for ikea sinks. Call or go to ikeas website maybe they can help you.
Others will be along with more advice/suggestions. Maybe someone else has used them before. Good luck.
jmon is offline   Reply With Quote
Old 08-02-2015, 09:36 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 780
Here are some for kitchen sinks and bathrm lavs--
http://www.efaucets.com/f/offset-tailpiece.shtml
Old 08-02-2015, 09:52 AM   #4
Rewards Points: 434
Thanks Eplumber, someting like the Elkay "offset" tailpipe should do the job.
Old 08-02-2015, 10:11 AM   #5
Plumber
Rewards Points: 780
You should be able to find it in tubular plastic as well- might save you a little money.
The Following User Says Thank You to TheEplumber For This Useful Post:
jmon (08-02-2015)
Old 08-02-2015, 01:18 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 692
Pretty chrome pipes but very $$$. Why could you not do the same with PVC slip fittings?
Use a threaded 90 elbow directly to the drain basket, pipe to the back wall, 90 down to the trap.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 08-03-2015, 01:44 PM   #7
Rewards Points: 721
Look for something that they use on wheelchair accessible sinks.
ct18 is offline   Reply With Quote
Old 08-03-2015, 09:10 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 996
Careful some codes won't let you offset kitchen sink traps.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-04-2015, 06:45 AM   #9
Rewards Points: 434
Thanks for the heads up. My city follows the 2009 international residential building code.
What's the thinking behind not allowing an offset?
Old 08-04-2015, 06:59 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 692
Isn't any center drain set up for a double bowl sink am offset drain?
Washing machine making "glugging noise"; kitchen sink backing up; bad smells; UGH KDG Plumbing 5 01-04-2015 06:27 PM
Kitchen Sink Drain marcopolio Plumbing 4 12-03-2012 09:03 AM
Replace old kitchen sink drain or leave it? CoconutPete Plumbing 23 02-02-2012 01:20 PM
venting kitchen sink drain illinifan Plumbing 2 05-03-2009 07:26 AM
Kitchen remodel, sink drain rework pinkertonpv Plumbing 3 02-18-2009 10:06 AM
