Kitchen Sink Spray Diverter? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2015, 11:14 AM   #1
"Old" Newbie
Rewards Points: 177
Having a problem with my kitchen sink faucet. Can't find a brand name anywhere. Central gooseneck with hot and cold levers to left and right and a spray hose. Spray hose work fine but suddenly lost pressure through central faucet, hot and cold to the goose neck.
Checked aerator; no constriction there or further up the "pipe".
Removed as much of the innards as I could. Nothing appears broken.
Wondering what would happen if I removed the diverter? Water to the main pipe but not the spray?
Looks like maybe the rubber gasket at the lower end of diverter is sticking in the "up" position. Should it drop down freely? If that were the problem, maybe removing the diverter, or trimming the gasket slightly, might help?
Been to Lowes and H.Depot. Nothing close. It's an old faucet. Planning to redo the kitchen in the next year, but hoping for a cheap fix on this faucet until then.
Any suggestions greatly appreciated.
RCrosby257 is offline   Reply With Quote
Old 12-13-2015, 11:19 AM   #2
GrayHair's Avatar
Rewards Points: 1,438
Some pictures of the faucet please.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Old 12-14-2015, 01:14 PM   #3
"Old" Newbie
Rewards Points: 177
diverter
Grey Hair,
Thanks for the response. Working on the pics.
May take a day or two.
Stay tuned.
Rob
Old 12-16-2015, 01:33 PM   #4
"Old" Newbie
Rewards Points: 177
Sink Diverter
GreyHair,
Hope this isn't too much trouble. Still trying to figure out how to post pics, but hopefully the following link will give you quick and easy access to what I have.
householdstuff127.shutterfly.com/pictures#n_5
Thanks again,
Rob
Old 12-19-2015, 12:38 PM   #5
"Old" Newbie
Rewards Points: 177
Sink Diverter
GrayHair
REALLY appreciate your hanging with me on this.
Got your request to access my shutterfly, but haven't been able to figure out to handle it on this end, yet!
No at home wifi, and the holidays upon us, so enjoy however it is you celebrate and I'll try again after Christmas!
Thanks,
Rob
Old 12-19-2015, 01:21 PM   #6
Tizzer's Avatar
Rewards Points: 148
Since you're redoing the kitchen later, why not buy a $30 faucet and be done with it.
Tizzer is offline   Reply With Quote
Old 12-19-2015, 03:16 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
Why not buy the faucet you will use in the new kitchen and reuse it? And save the $30.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 12-20-2015, 06:22 PM   #8
"Old" Newbie
Rewards Points: 177
|Message board
Use [email protected]
This may do it for the pics. Otherwise, I'll likely go with the new faucet option. Makes sense, I just hate not being able to figure it out! ;-)
Old 12-20-2015, 07:07 PM   #9
Rewards Points: 582
remove diverter and apply some faucet lube to it ....worth a try..if that don't work take diverter to local hardware and try to match it up...
Kitchen Sink Venting pool Plumbing 1 02-15-2014 09:37 AM
Kitchen Faucet Sprayer Does Not Work. Already Replaced Diverter. latenight Plumbing 13 08-12-2013 04:27 PM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 09:16 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
