Kitchen Sink Rough In Height - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2015, 03:48 PM   #1
Rewards Points: 322
Kitchen sink rough in height
I am installing a new sink in my kitchen. The counter is at 36 inches, and the sink is 8 inches in depth. It is a single sink.
The drain pipe is not in the wall, it is in the cabinet itself only it is about 2 feet away from the sink location. Am I safe to run a horizontal on slope pipe from the sink to where the pipe is? There is a vent extending upwards from here through the roof.
Also I'm looking to know the proper height for the stub out on this pipe. Again it is a single sink, however there will be a dishwasher Y added so I'd like enough height on the vertical pipe to connect this as well.
Thanks!
Sent from my iPhone using DIY Forum
Lemkie is offline   Reply With Quote
Old 03-11-2015, 04:06 PM   #2
Rewards Points: 582
Thanks!
need a picture of what you have...
Old 03-11-2015, 04:32 PM   #3
Rewards Points: 3,130
Don't forget to factor in a disposal if you ever intend to install one. If so, the stubout will likely need to be lower. Disposals won't pump uphill (don't ask how I know this).
Old 03-11-2015, 05:00 PM   #4
Rewards Points: 322
Thanks for the tip. There will not be a disposal though. I imagine you learned this the hard way!
Old 03-11-2015, 05:02 PM   #5
Rewards Points: 322
Actually I just cut out the existing plumbing, leaving the vent. So there is nothing there at the moment.
Really all it is is the hole in the floor about 2 feet to the left of where the sink will be, and the vent above this hole...
Old 03-11-2015, 06:24 PM   #6
Rewards Points: 1,952
Is this a single or double bowel sink? I would move the pipe in the wall and come out on the correct center for the bowel. Normal rough is 16 off the floor to center of drain. Lower is always better.
To answer the question a 2 foot extension from the vent is fine then a P trap.
Old 03-11-2015, 06:33 PM   #7
Rewards Points: 322
Originally Posted by Ghostmaker
Is this a single or double bowel sink? I would move the pipe in the wall and come out on the correct center for the bowel. Normal rough is 16 off the floor to center of drain. Lower is always better. To answer the question a 2 foot extension from the vent is fine then a P trap.
It is a single bowl sink
Unfortunately I can't move the pipe as it runs right next to a beam on the floor under it. I can't move the sink either as it's going to be centered with a window.
Essentially what I will have is a pipe coming down off the drain, a p trap, the. 2 feet on grade horizontally to connect to the existing pipe, then it will drop down with a vent on top. Is this ok?
Old 03-11-2015, 06:36 PM   #8
Yes as long as your vent is straight off the top and has no horizontal bends.
Old 03-11-2015, 06:39 PM   #9
Rewards Points: 322
Great. The vent goes straight up through the roof with no bends.
Thanks for the quick replies!
Kitchen Sink Venting pool Plumbing 1 02-15-2014 09:37 AM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 09:16 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
How difficult to remove a kitchen sink? Ultrarunner2017 Plumbing 6 11-14-2008 03:28 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
