Kitchen Sink. Main Pipe To Wall Is Clogged. How To Clear? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Evstarr
  • 1 Post By Mathlete
Old 08-28-2016, 10:39 PM   #1
Rewards Points: 265
Kitchen sink. Main pipe to wall is clogged. How to clear?
I took apart the smaller pipes, and I used a boroscope to see the clog was in the large pipe exit coming from the wall. It is clogged and I see a small pool of water.
I tried to jam a coat hanger and other stuff to no avail.
What sort of tool do I need to clear it?
Snake? Or some sort of drill attachment?
Is there a special technique?
Mathlete is offline   Reply With Quote
Old 08-28-2016, 11:07 PM   #2
Re: Kitchen sink. Main pipe to wall is clogged. How to clear?
One similar to this drain snake would be my suggestion
jeffmattero76 likes this.
Evstarr is offline   Reply With Quote
Old 08-29-2016, 10:31 AM   #3
Rewards Points: 265
I borrowed an electric one!
Old 08-29-2016, 11:03 AM   #4
Rewards Points: 265
Like this
http://www.ebay.com/itm/Milwaukee-He...-/322240707032
Old 08-29-2016, 11:43 AM   #5
Rewards Points: 2,560
Did it fix the problem?
bob22 is offline   Reply With Quote
Old 08-29-2016, 01:00 PM   #6
Rewards Points: 265
Yea, it seems to have done the trick. I only figured out how to use the electric snake tool at the very end. When pulling in and out, you need to secure the drill chuck so the cable is locked. I assembled it and ran water for a while, and it's clear.
bob22 likes this.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Washing machine making "glugging noise"; kitchen sink backing up; bad smells; UGH KDG Plumbing 5 01-04-2015 06:27 PM
Slow drainage and gurgling, overflow in kitchen sink daluu Plumbing 10 04-06-2014 10:29 PM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
