Kitchen Sink Drains Into Other Side Of Sink - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
Old 02-02-2017, 04:44 PM   #16
Rewards Points: 78
Re: Kitchen sink drains into other side of sink
Originally Posted by Ghostmaker View Post
California has great tenant landlord laws. Do not be afraid to use them.
Yes, I agree. Unfortunately the reality of working with a very controlling personality is that they can make your life miserable. Esp. if they resort to lying & you don't. I guess that's life. Thanks.
Nik333 is online now   Reply With Quote
Old 02-11-2017, 06:01 PM   #17
Rewards Points: 78
Is there a simple reason why the bathroom sink pipes would now begin to leak at the connections? It was the shower pipes, then after the tremendous rains, the kitchen sink outside pipes, now the bathroom sink pipe connections?
I forgot to mention that the house sits in a bit of a depression. It didn't really matter during the drought, but the ground is supersaturated now.
Also, there is a concrete foundation, I misspoke earlier.
I was wondering of the change in ground or air saturation, from very dry to very wet, could also affect the pipes?
Old 02-15-2017, 03:36 AM   #18
Rewards Points: 6
Originally Posted by Druidia View Post
OR it could mean that the drain pipe behind the wall is blocked.
I have a large pedestal sink for bathroom. Water in the smaller (higher) sink would swell up the larger lower sink before disappearing. There's no blockage in the pipes (new) under the sink. I had to replace the 70+ year-old metal pipe behind the wall (inner diameter of old pipe had been greatly reduced through the decades).
Have you tried sealant to block the leaking? If not then first try to seal it instead of replacing the whole sink.
jamie96 is offline   Reply With Quote
Old 02-16-2017, 07:25 PM   #19
Rewards Points: 78
What that means is you need to snake the kitchen sink line. It's blocked.
Originally Posted by Bondo View Post
Ayuh,.... It could be blocked 'bout anywhere, downstream of the sinks,.....
Ayuh it was blocked outside the house. It was snaked after 12 days. He never got anything, it just cleared.
If I don't know what to do, & ask for it, they won't do it! It helps tremendously to have this information. Thanks
The bathroom sink leakage was just a rusted hidden hole in a pipe, so the pipe was replaced.
Bondo likes this.
Find the best kitchen sink for your kitchen sheila06 Appliances 1 01-28-2017 11:29 AM
Drain Route and Venting for new kitchen sink drain (window above sink) joemc3 Plumbing 12 11-05-2016 06:17 PM
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 10:43 PM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 02:39 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
