Kitchen Sink Drain Baskets - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2016, 06:33 PM   #1
Lord of Slums
Rewards Points: 1,974
Kitchen sink drain baskets
I have a leaking double bay stainless steel sink. Their is no garbage disposal. Can I use silicone instead of plumbers' putty. Also can that rubber gasket be used on the top side of the sink? The basket is leaking
I have never used anything besides putty on the basket, so this is why I ask. I have used silicone around the sink itself.
mj12 is offline   Reply With Quote
Old 05-16-2016, 06:41 PM   #2
Rewards Points: 3,492
Re: Kitchen sink drain baskets
Yes, you can use the silicone, works better than plumbers putty imo.
The rubber gasket is best to be use as a seal underneath, use silicone for seal on top if you want. Just a suggestion.
jmon is online now   Reply With Quote
Old 05-16-2016, 08:34 PM   #3
Rewards Points: 1,952
100% silicone, not the water based stuff.
Old 05-16-2016, 08:40 PM   #4
Lord of Slums
use a good amount of silicone then just wipe off the excess? It will not stain the sink? Should I tape around the edges? How long should it set before drying?
Old 05-16-2016, 11:24 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 290
Put about a 1/4" bead around the basket flange, set it in the hole. Apply slight pressure while giving it 1/8 turn. Install the gasket and nut on the bottom side.
Carefully wipe off excess caulk- don't smear it around. Clean up the film with denatured alcohol. You can then test for leaks.
The Following User Says Thank You to TheEplumber For This Useful Post:
gregzoll (05-17-2016)
Old 05-17-2016, 06:36 PM   #6
Lord of Slums
Worked out much better than I thought it would. Their was a little silicone left in the grove around the basket. I wiped everythig pretty well, I just did not dig it out of the grove. Will that cause a problem? And as far as I am concerned I will never use putty again
The Following User Says Thank You to mj12 For This Useful Post:
Old 05-17-2016, 07:16 PM   #7
Rewards Points: 6,652
I leave a small bead where the strainer meets the sink, then take a Cotton Swab with the swab removed off of one end, to press it down after it sets for 15 min's. Then leave alone for a day or so, before you run any water in the sink.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Kitchen Sink Drain Vent Tfraser Plumbing 21 06-30-2015 04:55 AM
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 10:43 PM
Clogged kitchen sink drain..! abbyqueue Plumbing 3 04-04-2012 07:17 AM
kitchen revamped, help with sink drain plumbing rfire15 Plumbing 6 09-29-2011 08:45 PM
