Kitchen Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2018, 12:19 PM   #1
Rewards Points: 32
Kitchen pressure
Hi, thanks for looking at this for me. Ok so here it goes. I cleaned my faucet in the kitchen with CLR. It had a lot of hard water in it so I let it soak for 2 min and then turned on the faucet to clean it all out. After this the water pressure seems to be a lot less and now my dishwasher isn't rinsing off a all the soap. I checked my outside water line for the pressure and it was between 40-60. Do I or can I increase the pressure at the kitchen sink? Will that improve the dishwashers rinse function? Should I ask in appliances also? Any help would be great.
vegasbird is offline   Reply With Quote
Old 01-03-2018, 01:33 PM   #2
Rewards Points: 6,108
Re: Kitchen pressure
40 - 60 pressure is definitely enough.
I would check the aerator/screen at the faucet and the filter etc., at the dishwasher.
https://www.google.com/search?rlz=1C....0.lxhntsY8Hgc
Also buy a pool test kit and check the water.
Do you have city water or well water, and have you checked it before.?
Do you have a whole house filter and when was it changed.?
ron45 is offline   Reply With Quote
Old 01-03-2018, 01:59 PM   #3
Rewards Points: 32
The faucet doesnt have that. the house was built in 2008 on city water. No idea if there is a whole home filter. I don;t think so or I think I would remember. Would low pressure in the kitchen cause my dishwasher to not work properly? As in not rinsing off good enough?
Old 01-03-2018, 02:03 PM   #4
Rewards Points: 32
As for the dishwasher i cleaned the filter inside. cleaner everything inside. never helped.
Old 01-03-2018, 02:28 PM   #5
Rewards Points: 88
Did you turn the water supply valves off to the kitchen sink faucet when you cleaned it ? A lot of plumber's will "t" off the kitchen faucet water supply line to feed the DW.
If yours is plumbed in this way, the water supply valve may have a clog in it that was dislodged when you shut it off, or a valve seat/ O ring that is twisted out and reducing the water flow to the sink and DW. Just a thought.
JMO
Gregsoldtruck79 is offline   Reply With Quote
Old 01-03-2018, 02:43 PM   #6
Rewards Points: 32
Ok so the hard minerals that the for might have backed up into both or all 3 of my lines? So just tear it apart and clean the lines?
Old 01-03-2018, 02:44 PM   #7
Rewards Points: 32
I did have the faucet head pulled down and thought I would flush anything out first, but who knows.
Old 01-03-2018, 04:52 PM   #8
Rewards Points: 680
Your dishwasher fills with clean water then pumps it through the spray arms to rinse. Your water pressure has nothing to do with it.
LawnGuyLandSparky is offline   Reply With Quote
Old 01-03-2018, 05:08 PM   #9
Peace be with you
DR P's Avatar
Rewards Points: 1,860
did you cycle (close & then open) any stop/control valves to faucet under kitchen sink?
does DW have its own stop calve or is it dual outlet control for both kitchen faucet and DW? Is cold water flow at kitchen faucet better than hot flow to kitchen faucet?
Peace
DR P is offline   Reply With Quote
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 05:36 PM
Water Heater Replaced, Now no HW pressure in Kitchen LakeShoreLtd Plumbing 4 06-20-2012 07:26 AM
Kitchen faucet pressure manemger Plumbing 3 09-27-2011 05:31 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Low Water Pressure Only on Kitchen Faucet Chsmadden Plumbing 4 03-21-2010 09:01 PM
