Kitchen Plumbing Help - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 06-05-2016, 09:03 PM   #16
Rewards Points: 118
Re: Kitchen plumbing help
The thicker the diameter of the coil, the stiffer it will be. So when you push against a clog 40 ft away in the pipe, the coil will have less flex to bend up some where in the middle. Off course when pushing against a clog you'll also need to spin the head so it can dig into the mess.
The 50 ft x 1/2 inch coil saved me tons of $$$. Highly recommend it. It's also not very expensive... at 27 bucks I used it and tossed it away in the garbage bin without any remorse.
Originally Posted by mathmonger View Post
Interesting. Why does the diameter of the cable matter. I always figured the head did all the cleaning.
nilanjan is offline   Reply With Quote
Old 06-08-2016, 07:33 PM   #17
Rewards Points: 1,866
Grease clogs tend to re block with small snakes. I also ran hot water down the drain for a while after getting it open. I would also suggest you purchase a can of Bio Clean.
Old 06-09-2016, 09:18 AM   #18
Rewards Points: 118
Hi,
Are you referring to Bio-Clean Spectic Bacteria? I've seen the stellar reviews for it on Amazon but I'm just a bit fearful to use it because it's a "bio" & "bacteria" agent. According to the product description it is activated with water and then it multiples on it own. Sounds like an effective product... it can work vertically in the pipe system against gravity where as the other chemical agents cannot.
I would have to apply it from the kitchen sink and then wash i down with water so it goes into the pipe. Concern is the bacteria multiplying onto the sink, dishwasher, counter top, etc... and getting onto food and spreading like that Am I being over cautious? How would you contain it to the pipe system?
Can someone please chime in on this to clarify.
Thanks!
Old 06-09-2016, 08:10 PM   #19
I've been using it for 17 years and never had to snake any drain in the house. I highly recommend it. It eats hair, grease, scum and all the little nasty's. It will not hurt the pipe. It does do one nasty thing though it poops water as a waste.
P.S. you can eat this stuff it's that safe.
Kitchen sink plumbing: Is this an 'S' trap? jsweet1981 Plumbing 14 01-01-2013 11:06 AM
New Kitchen sink plumbing locations oscar62 Plumbing 4 05-17-2011 07:46 PM
DIY Kitchen Island Plumbing question - 2 bayin Plumbing 3 03-28-2011 08:29 AM
kitchen sink plumbing w/extra pipe adams33064 Plumbing 20 05-19-2010 11:22 PM
Kitchen Remodel Plumbing johnpma Plumbing 2 06-19-2009 09:13 PM
