Kitchen P-Trap Assembly Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2015, 11:36 AM   #1
Rewards Points: 368
Hi all! I am replacing the drain assembly under the kitchen sink. I mocked up an ABS assembly and I have a question about the p-trap. I figured it would be best to use a p-trap with a union... I also bought one with a clean-out plug, but the union seems like a better option - should anything fall into the drain, a clog, etc. I also figure that a union would allow easier incorporation of a garbage disposal... should I ever decide to install one. The old ABS assembly had a p-trap w/ union.
Haven't glued it up yet. Does everything look okay? Am I correct in my logic in wanting to use the p-trap with the union?
Thank you!
Kitchen P-Trap Assembly Question-drain1.jpg   Kitchen P-Trap Assembly Question-drain2.jpg
Kory Beam is offline   Reply With Quote
Old 12-01-2015, 03:05 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I would go with your mock up. It is a personal preference but I prefer having the union.
I like the way the hot and cold are plumbed in a$$backwards.
If that is a kitchen sink, I predict your wife will hate it. I know because I just finished cutting my granite it install a larger sink.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 12-01-2015, 03:20 PM   #3
Rewards Points: 368
Thanks, rj! Yes, it does look like the hot and cold lines are reversed, but they are correct. Just come out the single hole of the faucet and are slightly long. You made me panic for a second
The Following User Says Thank You to Kory Beam For This Useful Post:
oh'mike (12-01-2015)
Old 12-01-2015, 08:54 PM   #4
Rewards Points: 1,848
Looks fine but an LA trap would be a better option.
http://www.truevalue.com/product/1-1...ullDescription
Old 12-01-2015, 09:01 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
LA trap?
Old 12-01-2015, 10:00 PM   #6
Originally Posted by rjniles View Post
LA trap?
That's what we used to call them in Ohio.
Septic floor drain trap question dontilgon Plumbing 6 03-18-2013 08:14 AM
Kitchen sink plumbing: Is this an 'S' trap? jsweet1981 Plumbing 14 01-01-2013 11:06 AM
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 09:13 PM
Bathroom Trap Question... Mozart Plumbing 4 07-19-2011 06:25 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
