Kitchen Faucet Smells Like Rotten Eggs/Sulfer - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-17-2017, 06:42 PM   #1
Rewards Points: 106
About 2 months ago I installed a new kitchen faucet. Over the past week we have been getting the smell when we first turn the water on.
If the water runs for about 20 seconds, the smell goes away.
We do not have this smell through any other faucet or in the showers.
We have a well and do not have a softner.
The main water lines are pex and I used the braided steel for the supply from the pex to the faucet.
Any ideas what could be the problem?
cjenkins08 is offline   Reply With Quote
Old 06-17-2017, 07:07 PM   #2
Rewards Points: 6,464
Re: Kitchen Faucet Smells Like Rotten Eggs/Sulfer
I installed a new faucet in the utility sink with a hose/sprayer and that same problem smell lingered in the hose/sprayer only, not water from the faucet, for nearly 2 years. It would finally clear of the odor after about a quart of water was run through it.
I sanitized the well with bleach several times during that period being sure the bleach odor reached the sprayer valve but those measures didn't seem to help. All I can deduce is the odor was in the manufacture of the hose and the smell eventually went away.
Does both the cold and hot have the objectionable odor?
Sometimes the aerator screen develops an odor but that doesn't seem reasonable with yours. I wish I had better info. for you but I don't.
Old 06-17-2017, 07:30 PM   #3
Rewards Points: 76
There are a lot of threads on this. I remember the discussions. Since this is a holiday weekend, some may be away. You may want to check this out -
http://www.diychatroom.com/search.php?searchid=24351226
Nik333 is online now   Reply With Quote
Old 06-18-2017, 08:17 AM   #4
Rewards Points: 100
i dont think its your faucet. i think you have poorly vented drain line at the kitchen sink and what you are smelling is the gases from the drain line. you need to have professional plumber to look at it since you listed all new water lines but nothing on how your vent stacks is setup to the kitchen. i am willing to bet its either not installed correctly or missing vent.
radioman99 is offline   Reply With Quote
Old 06-18-2017, 10:14 AM   #5
Rewards Points: 106
I let the faucet sit overnight, unused.....when I turned on the hot water, there was no smell....when I switched it to cold water, the smell was there.
This should narrow it down to the pex line going to the faucet or somewhere in the faucet.
Short of replacing the faucet, is there anything else that can be done?
A kitchen faucet can change your kitchen look sheila06 Appliances 12 02-13-2017 03:27 PM
Outdoor Kitchen and garage faucet plumbing plumlost Plumbing 7 11-09-2014 09:01 AM
Kitchen Faucet - No hot water, just a trickle french69ssrs Plumbing 4 02-11-2013 01:14 PM
No water from my kitchen faucet? bizzy1028 Plumbing 7 06-07-2011 02:16 PM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 08:19 PM
