Kitchen Faucet Mounting Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2016, 04:05 PM   #1
Rewards Points: 22
Hello everyone,
Shown is the underside of our kitchen faucet. The assembly is held against the wooden panel by the hex nut, which I had been tightening every few weeks. The assembly moves to the side when it is loose and some splashed water drips in, as the edge of the drilled hole in the countertop becomes exposed (you can see the wetness in the wood). I had put some paper in between the wood and the white plastic and then I tried something not as smooth (sandpaper) hoping it would provide some resistance against moving side to side. The movement/looseness I think comes from constant use of the swing-arm of the faucet.
My questions are (1) is there anyway to improve this set-up, so it would be more stable (2) I am now worry about water that is already in the wood and any that will potentially seep in there in the future. Is there anyway to dry it or attach some kind of dessicant onto the wood?
Thank you.
cl6120 is offline   Reply With Quote
Old 04-04-2016, 05:17 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,248
Re: Kitchen Faucet Mounting Issue
Ayuh,.... It oughta dry out by itself in a few days or weeks, once ya stop the water,.....
I'd probably take it apart, 'n start over,....
Clean, 'n dry the hole as best ya can with paper towels or what not,....
Caulk the top with a poly-vinylsulfide caulk, assemble, 'n tighten it in, Good, 'n Tight,....
Once the caulk sets up, it oughta be Good to Go,....
Bein' a Boater, I'd use Dupont 5200, or 4200,....
Old 04-04-2016, 06:48 PM   #3
Rewards Points: 352
check if the spout turns everything when you swing it side to side, the spout is made to turn independently of the base but sometimes they fail.
plumberinlaw is offline   Reply With Quote
New Kitchen Faucet Kathy642 Kitchen & Bath Remodeling 1 07-17-2015 06:52 AM
Loose Kitchen Faucet - Single Spout Moen Klammern Plumbing 2 07-01-2015 05:50 PM
Kitchen Faucet Sprayer Issue Sojumonkey Plumbing 6 07-11-2014 06:30 PM
Hot/Cold mix question on kitchen faucet JeffL Plumbing 4 01-01-2012 07:13 PM
