Kitchen Faucet Input Tube Broken!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2015, 01:35 AM   #1
Rewards Points: 1,428
Unhappy
Kitchen Faucet input tube broken!!
I got a bit of a problem...
Do you know those copper tubes that stick out of the bottom of the faucet and at the end there is a thread that you connect your flexible tube to?
Well one of them in our faucet has broken when I screwed the tube back on!
I think it was creased by being bent against the... skirt of the faucet that has threads for the nut to screw onto.
Then when I screwed the tube back on, it broke!
The damn faucet was like $100! And the damn thing broke! Such a poor design of the copper tubes that break so easily!
So... is there any way to fix this??? Can the copper tube be soldered together with a coupling? Or is the faucet ruined?!
poiihy is offline   Reply With Quote
Old 11-28-2015, 08:39 AM   #2
Rewards Points: 1,854
They do make 3/8 inch couplings but you will need to have nice rounded pipe to attach it to on the faucet.
Old 11-28-2015, 12:57 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I would use a Sharkbite 3/8"x1/2" MNPT male adapter. Cut the copper above the kink to make sure it is round.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Ghostmaker (11-28-2015)
Old 11-28-2015, 08:30 PM   #4
Ok I will look into the Sharkbite connectors...
The damage is right at the skirt so it is hard to access but I found that the skirt can be unscrewed from the faucet so that I have full access to the tubes. Problem is how to get the skirt off because it is narrow and the thread connectors at the end of the tubes are in the way... hopefully I can get it off.
Old 11-28-2015, 09:18 PM   #5
I got the metal skirt off without much trouble. Here is what it looks like. Can a shark ite connector fit there?
Kitchen Faucet input tube broken!!-3edda842-d1fd-4d40-8b87-3b9cb103f446.jpg   Kitchen Faucet input tube broken!!-fcbaa291-deb5-4be8-97cb-385529dfa68e.jpg
Old 11-30-2015, 11:40 AM   #6
Rewards Points: 1,336
Clean up both broken ends real good and get one of these...
http://www.homedepot.com/p/Sioux-Chi...1210/202254844
danpik is offline   Reply With Quote
Old 11-30-2015, 12:01 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Where the break is located I think a Sharkbite or a compression fitting will be too large. I would get a 3/8" sweat coupling, a short piece of 3/8 copper tube and a 3/8 by 1/2 male adapter.
Old 12-01-2015, 01:22 AM   #8
A 3/8" Sharkbite connector was way too big! Even a 1/4" Sharkbite connector was too big!!!
I tried a "Watts 3/8 OD Compression Coupling". It seemed like it was going to fit and I measured the outer diameter of the tube and it was 3/8 so it should have fit!
It took a forkload of force to tighten that piece of garpage before it would actually hold on the tube... the first tube finally became secure after tightening it bloody hell damn tight... but then the other side did not hold and I tightened that overpriced piece of garbage as tight as possible and the bloody tube was atill flapping around in the breeze! Then the other side became loose!!!!!!!! absolute hell nightmare piece of garbage coupling and it cost freaking $6!!
UGH!
Old 12-01-2015, 01:23 AM   #9
That's the piece of sheat I used and it didn't work at all!!
Old 12-01-2015, 01:24 AM   #10
Is a sweat coupling a simple copper sleeve that needs to be soldered?
Old 12-01-2015, 01:29 AM   #11
And yes I cut the tubes so the ends were round and filed them nice and smooth!
Old 12-01-2015, 05:31 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Bingo!
Tags
broken , copper , kitchen faucet , tube
New Kitchen Faucet Kathy642 Kitchen & Bath Remodeling 1 07-17-2015 06:52 AM
Loose Kitchen Faucet - Single Spout Moen Klammern Plumbing 2 07-01-2015 05:50 PM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
Laundry faucet & trap seal tube connections Bri Plumbing 1 07-01-2010 09:51 PM
