Kitchen Faucet Aerator Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2016, 11:00 PM   #1
ZZZZZ's Avatar
Rewards Points: 2,512
Kitchen faucet aerator question
So as followup to my http://www.diychatroom.com/f7/milky-...-water-404721/ issue, I cleaned out my faucet aerator.
It was pretty clean, but I found that there were three metals screens in there. Is multiple screens in the aerator a common feature?
This is a very nice pull-down faucet that I received as a gift, but it is made in China and there are no instructions or specs about the aerator.
Thoughts?
ZZZZZ is online now   Reply With Quote
Old 06-16-2016, 07:39 AM   #2
Rewards Points: 1,328
Re: Kitchen faucet aerator question
Last time I looked almost everything was made in china. What's the brand? Even made in china the brand should be calling the specs. If multiple screens, maybe a cheap way of breaking up the flow instead of using the usual plastic things.
I just replaced the kitchen faucet, american standard goose neck pull down. I removed the restrictor, gone in a trash, and wish I hadn't. House pressure isn't that high.
carpdad is offline   Reply With Quote
Old 06-16-2016, 08:14 AM   #3
ZZZZZ's Avatar
Hardware House brand. Don't know if my sister bought it at Houzz, but here it is.
http://www.houzz.com/photos/8428634/...itchen-faucets
Old 06-16-2016, 08:44 AM   #4
Household Handyman
Rewards Points: 1,412
Yes ZZZZZ, some faucet aerators have multiple screens. I have found as many as three (3) screens in one aerator. I have also noticed that the screens are put together on a 45 degree pattern. The second one goes 45 degrees to the first and the third goes 45 to the second which puts the third the same as the first one. Must have something to do with aerating the water.
The Following User Says Thank You to Thurman For This Useful Post:
ZZZZZ (06-16-2016)
Old 06-16-2016, 08:56 AM   #5
ZZZZZ's Avatar
Thanks, I didn't notice the alignment of the screens when I took it apart, as I kind of fumbled the pieces when I opened it up. I will take it apart again and line up the screens as you suggest.
Outdoor Kitchen and garage faucet plumbing plumlost Plumbing 7 11-09-2014 09:01 AM
Kitchen Faucet Sprayer Does Not Work. Already Replaced Diverter. latenight Plumbing 13 08-12-2013 04:27 PM
Kitchen Faucet need2speed75 Plumbing 17 03-10-2013 10:25 AM
Kitchen Faucet - No hot water, just a trickle french69ssrs Plumbing 4 02-11-2013 01:14 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
