Kitchen Drain Clogged - Snake Got Into The Kitchen - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By SeniorSitizen
  • 1 Post By cprao
  • 1 Post By fireguy
Old 06-11-2017, 09:37 AM   #1
Rewards Points: 380
Kitchen Drain clogged - Snake got into the kitchen
My Kitchen drain clogged. For the first time, I want to clean myself and I used hydrostar power drain cleaner from the clean out, right outside the kitchen.
I spent almost 3 hours and it was going very very slowly.. but at the end I figured out that it did not go through the drain line towards the main drain line but instead it did get into kitchen towards faucet and broke one of the "P" traps.
How do we know where the drain cleaner is going ? How can I avoid such problems in the future ?
cprao is offline   Reply With Quote
Old 06-11-2017, 02:35 PM   #2
Rewards Points: 18,964
Re: Kitchen Drain clogged - Snake got into the kitchen
#1, Do not use a toxic drain cleaner, little late for that now.
I would have started by removing the trap under the sink and cleaning it out.
Next I would have ran a snake down the drain where it enters the wall making sure it want down not up into the vent line.
The way it is now your going to be working around a chemical that can cause skin burns and can blind you if it gets in your eye.
Old 06-11-2017, 03:43 PM   #3
Big Dog
Drachenfire's Avatar
Rewards Points: 4,884
Had a similar problem. Kitchen sink clogged during dishwasher cycle. Tried to plunge it with no success. Pulled the trap, found no clog. Had a 25' drain auger and ran it to the max, no joy. Called in a plumber who broke out a machine auger. He had to feed over 40 ft of snake before clearing the clog. Still not sure what clogged the pipe as nothing came back when he pulled the snake.
My point is sometimes you just have to call in a professional.
Drachenfire is offline   Reply With Quote
Old 06-11-2017, 04:00 PM   #4
Rewards Points: 6,354
I think the OP is talking about this: http://www.ebay.com/sch/i.html?_nkw=...+drain+cleaner
Not a chemical drain cleaner.
Nik333 is online now   Reply With Quote
Old 06-11-2017, 04:33 PM   #5
JUSTA MEMBER
Rewards Points: 3,812
Most of those clean outs are a Double clean out.
Meaning that there should be two caps in the line in a row, the closer one to the house goes to the street, the farther one goes inside.
Did you use the correct access point?
ED
de-nagorg is online now   Reply With Quote
Old 06-11-2017, 04:49 PM   #6
Rewards Points: 6,378
If it's a single clean out fitting I can see one of two things causing the snake to go the wrong direction. The clean out fitting was installed 180 wrong or there was a T installed rather than a clean out fitting.
de-nagorg likes this.
Old 06-11-2017, 08:06 PM   #7
Rewards Points: 380
Thank you for all your responses.
Yes. It is not a chemical drainer and it is a powered drain cleaner with 50 feet long cable.
I have only one clean out and this is the clean out used by the professional in the last two or three times when the kitchen is clogged out.
I am calling a professional tomorrow to see whats wrong and figure it out the problem.
Nik333 likes this.
Old 06-13-2017, 01:12 AM   #8
Rewards Points: 996
I used my hot water pressure washer. It puts out 3,000 PSI, with a zero nozzle and 160 F water. I do not have a sewer nozzle, nor do I have the 1/8" hose. So I made do with a 15 nozzle and made a short 3/8 ID x 25 foot hose, connected to my gun. I pulled the brass plugs out of the sewer pipe. Dee ran the gun, I pushed and pulled the hose. 3,000 PSI and 160F makes that **** move right along. And, I did not have to rent the snake or the jetter.
Video starts with a cable, then 5 minutes in they use a jetter.
Dave Sal likes this.
fireguy is offline   Reply With Quote
Old 06-13-2017, 01:54 PM   #9
Rewards Points: 1,054
Many times it's better to use a hose and weenie (drain clearing bladder) to clear a clog. The trick is finding a hose that's not too flexible or too rigid.
clarenceboddick is offline   Reply With Quote
Drain Route and Venting for new kitchen sink drain (window above sink) joemc3 Plumbing 12 11-05-2016 06:17 PM
Condo drain in upper unit caused drain in lower unit to leak? dangre Plumbing 15 07-09-2016 08:45 AM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
Kitchen Drain Dilemma DIYaholic Plumbing 4 01-13-2010 08:23 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
