Which Kind Of Pipe...What Size? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2015, 10:09 AM   #1
Rewards Points: 759
Which kind of pipe...What size?
I will be building a tractor storage barn & workshop combination on my property. I would like to bring over from the house to the barn an underground water line so I can hook up a wash sink & a connection to the veggie garden.
I will be digging a trench to burry the pipe run from the house to the barn, which will be about 75 feet (more or less) & I'm not sure what to use for the underground pipe run or the diameter of the pipe. I think I would like to use that water pipe that, is a heavy black plastic that comes rolled up & you use plastic fittings & stainless steel clamps. The main supply line on my house is 3/4" PVC that I can connect to. Or I can also connect to the outside hose sill cock on the side of my house. That would also shorten the run to the barn by about twenty five feet.
At the barn I want to install a four foot hydrant water fixture to connect a garden hose. On the inside of the barn, I want to have a wash sink. The buried line will be about eight inches deep. We really do not have a frost line here in upstate South Carolina, so I don't have to be concerned with water line freeze, however I would like to be able to open up the underground pipe & Blow out the line when not in use during winter just as a safety measure. Can someone help me with the materials needed and the pipe size for my project. Thank you.
maddog1 is offline   Reply With Quote
Old 08-20-2015, 10:30 AM   #2
Rewards Points: 5,348
Sounds like the black pipe you're describing is sprinkler pipe. No on that. Depending what is code for your area, you can run PVC, Pex or copper.
What is your water pressure at the house?
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
maddog1 (08-20-2015)
Old 08-20-2015, 11:01 AM   #3
Rewards Points: 759
The water pressure off the main supply is around 60 psi, but I will be checking it with a gauge to be sure. I'm here in South Carolina. But when I lived in NY, orange county, I do recall we had the coiled black pipe underground, five feet down, from the top of the well head, connection into the pressure tank in the basement of the house. The house was built by me 25 years ago & at that time that black coiled pipe was legal by code.
Here in SC, I don't think it will be an issue, but I would like to use the proper material. PVC 3/4" is what the plumber installed at my new house here in SC, from the meter into the crawlspace. The house lines for sinks, toilets, etc. are 1/2" lines.
Old 08-20-2015, 04:21 PM   #4
Rewards Points: 1,928
Make sure you find out your frost level so your ditch is deep enough. I would suggest pex because it is a house approved water line. Well pipe is usually only good to the pump/tank then they convert to a water line pipe. Your house piping is CPVC Biege in color not PVC white in color. Pvc is not approved for hot water .
The Following User Says Thank You to Ghostmaker For This Useful Post:
maddog1 (08-21-2015)
Old 08-20-2015, 05:05 PM   #5
Rewards Points: 8,645
Here but not all places that black pipe in the roll is poly and is approved for rural water lines both mains and subs. With a good loamy soil or some imported sand I would not hesitate to use for a run to the barn.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
Old 08-20-2015, 05:08 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 246
Pex is good.
The black pipe you speak of is called "poly" pipe. We install it on all domestic water services. It is available in copper tube size or iron pipe size- 160# or 200# is approved in our area. Do not use the lighter irrigation gauge though- I think it's 100#
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 08-20-2015, 05:41 PM   #7
Property Mgt/Maint
Rewards Points: 8,202
Smile
I did a similar job last fall, ran 100 ft of 3/4 pex out to a garage for seasonal usage.
In this case we dug down 30", back filled with 6" of sand, laid in the tube and covered with another 6" of sand. Dropped in a tracer wire and filled to within 6" of the surface and then added "Caution" plastic tape. The sand might be overkill but it keeps possible sharp rocks away from the tubing.
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 08-20-2015, 05:48 PM   #8
Civil Engineer
Rewards Points: 5,246
The black pipe is high density polyethylene (HDPE), available in long lengths and virtually any diameter. This type of pipe is routinely used for underground service, of course check with your local plumbing inspector to be sure it is OK. DO NOT confuse this type of pipe with PEX, which is cross linked polyethylene, and is typically not approved for underground use.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 08-20-2015, 06:31 PM   #9
Pex is approved for underground use under the IPC.
WATER SERVICE PIPE
MATERIAL
STANDARD
Acrylonitrile butadiene styrene (ABS) plastic pipe
ASTM D 1527; ASTM D 2282
Asbestos-cement pipe
ASTM C 296
Brass pipe
ASTM B 43
Chlorinated polyvinyl chloride (CPVC) plastic pipe
ASTM D 2846; ASTM F 441; ASTM F 442; CSA B 137.6
Copper or copper-alloy pipe
ASTM B 42; ASTM B 302
Copper or copper-alloy tubing (Type K, WK, L, WL, M or WM)
ASTM B 75; ASTM B 88; ASTM B 251; ASTM B 447
Cross-linked polyethylene (PEX) plastic tubing
ASTM F 876; ASTM F 877; CSA B 137.5
Cross-linked polyethylene/aluminum/cross-linked polyethylene (PEX-AL-PEX) pipe
ASTM F 1281; ASTM F 2262; CAN/CSA B 137.10 M
Cross-linked polyethylene/aluminum/high-density polyethylene (PEX-AL-HDPE)
ASTM F 1986
Ductile iron water pipe
AWWA C151; AWWA C115
Galvanized steel pipe
ASTM A 53
Polyethylene (PE) plastic pipe
ASTM D 2239; ASTM D 3035; CSA B 137.1
Polyethylene (PE) plastic tubing
ASTM D 2737; CSA B 137.1
Polyethylene/aluminum/polethylene (PE-AL-PE) pipe
ASTM F 1282; CAN/CSA B 137.9
Polypropylene (PP) plastic pipe or tubing
ASTM F 2389; CSA B 137.11
Polyvinyl chloride (PVC) plastic pipe
ASTM D 1785; ASTM D 2241; ASTM D 2672; CSA B 137.3
Stainless steel pipe (Type 304/304L)
ASTM A 312; ASTM A 778
Stainless steel pipe (Type 316/316L)
WATER DISTRIBUTION PIPE
MATERIAL
STANDARD
Brass pipe
ASTM B 43
Chlorinated polyvinyl chloride (CPVC) plastic pipe and tubing
ASTM F 1986
Ductile iron pipe
AWWA C151/A 21.51; AWWA C115/A 21.15
ASTM A 53
Polyethylene/aluminum/polyethylene (PE-AL-PE) composite pipe
ASTM F 1282
http://plasticpipe.org/pdf/pex_desig...ter_supply.pdf
Page 91 on.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
maddog1 (08-21-2015), Yodaman (08-20-2015)
Old 08-20-2015, 06:40 PM   #10
Property Mgt/Maint
Ghost, you beat me to it, just getting ready to site 2015 IPC 605.3 Water Service Pipe code.
http://codes.iccsafe.org/app/book/co...apter%206.html
Old 08-21-2015, 07:30 AM   #11
IPC and local codes do vary. Local code prevails.
Colbyt
Old 08-21-2015, 09:41 AM   #12
Rewards Points: 759
Thank you everyone. Now that I have got the advice on the pipe material, what size pipe do I run from the house to the new construction barn. I assume 3/4" I.D. will work to go out as the main supply, then if I add a slop sink I will reduce down to 1/2"
Is the 3/4" ok for a main run of 50-75 feet. My water use at the new barn will not be much at all. Just a sink & a hose connection to a vegetable garden. Thanks.
The Following User Says Thank You to maddog1 For This Useful Post:
TheEplumber (08-22-2015)
Old 08-21-2015, 11:59 AM   #13
Property Mgt/Maint
3/4 is plenty big enough. Some will try to convince you that 1/2 is big enough, and it is, but the cost differential between 1/2 and 3/4 for the total project is so little, that it makes no sense not to run 3/4
The Following 3 Users Say Thank You to Yodaman For This Useful Post:
Colbyt (08-21-2015), Ghostmaker (08-21-2015), maddog1 (08-21-2015)
Old 08-21-2015, 12:16 PM   #14
47_47's Avatar
Rewards Points: 320
Where do you plan on discharging the slop sink?
47_47 is offline   Reply With Quote
Old 08-21-2015, 12:42 PM   #15
Rewards Points: 759
Thanks. I thin I will be running the 3/4" pipe. Cost is not the issue with me. It's finding the best size to use. Thanks
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Pipe Size guymwf Plumbing 0 11-09-2011 12:37 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Pipe Size pochi Landscaping & Lawn Care 2 07-04-2009 03:13 PM
what kind of pipe to use clasact Plumbing 24 10-05-2008 12:48 PM
