Is This Just A Slip Nut? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2017, 02:43 PM   #1
Rav
Rewards Points: 898
Is this just a slip nut?
These are pictures of my sink drain (chrome-plated brass) going into the wall. It attaches to cast iron pipe there. I need to remove the wall bend where it goes into the wall. Is that a slip nut at the wall (like the other two slip nuts in the picture), and is that all that attaches the wall bend to the cast iron? If so, I assume I can just unscrew that nut counterclockwise and pull out the brass pipe. Should I use some penetrating oil to loosen it up, or apply some heat, to help ensure that I don't twist the cast iron pipe? The yellow stuff is just insulating foam. Thanks.
Rav is offline   Reply With Quote
Old 01-01-2017, 02:46 PM   #2
Rewards Points: 288
Re: Is this just a slip nut?
That should be just a slip nut. Give it some light taps around the edges with a hammer if it's stubborn but I doubt it'll give you much trouble to twist off.
BlackTiger is offline   Reply With Quote
The Following 2 Users Say Thank You to BlackTiger For This Useful Post:
Ghostmaker (01-01-2017), Rav (01-01-2017)
Sink leaking between tailpiece and slip joint Bcoleman6 Plumbing 6 05-31-2013 03:46 PM
Tips on soldering slip joint on vertical pipe? darsunt Plumbing 2 04-06-2012 03:26 PM
Help with DIY Slip n Slide Project ffrllc General DIY Discussions 9 08-05-2011 06:47 PM
Good tarp for DIY Slip n Slide? ffrllc General DIY Discussions 8 07-26-2011 09:49 AM
PVC Slip coupler msaeger Plumbing 5 03-13-2011 09:46 PM
