Joist Holes Sister Joist - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2015, 08:58 PM   #16
Rewards Points: 16
OK so the rubber fitting is a simple enough fix. Can you please describe the danger of the flat vent keeping in mind it is a dedicated vent for a kitchen sink. Also, unfortunately the joists are 12 feet. About 3-3.5 feet to one side of the holes.
ragart is offline   Reply With Quote
Old 11-10-2015, 05:08 PM   #17
Rewards Points: 1,856
I'll keep it simple, Dry flat vents over time will get clogged.... Now you have no vent and no way to clean it out. Also your vent needs to rise vertically above the trap of your sink trap. Your not venting anything when its below your trap.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (11-10-2015), Trucon01 (11-10-2015)
Old 11-10-2015, 06:05 PM   #18
Rewards Points: 16
can you contrast that with how you would clean out a clog in the horizontal portion with a properly vented system?
Old 11-10-2015, 10:24 PM   #19
When a sink gets blocked one removes the trap and snakes the drain. When a dry flat vent gets blocked do you plan on cutting open a wall cutting open a pipe to snake it?
Old 11-11-2015, 05:33 AM   #20
Rewards Points: 16
Fortunately its drop ceiling so not as bad as a wall.
Old 11-11-2015, 05:48 AM   #21
Rewards Points: 16
It just occurred to me that there might be a misunderstanding about the vent. It runs horizonal from the fernco about 3 feet to the left then goes vertical about 25 feet through my roof. Does that change anything?
Old 11-11-2015, 08:59 AM   #22
The question is how are you venting the new sink? This one does not do it.
Old 11-11-2015, 09:10 AM   #23
Rewards Points: 16
I have no idea. I max filled the sink and drained it all out at once. I could feel the air being pulled in on the roof vent stack. I'm not sure what alternatives I have. I have no wall access at this point and no way to tie it to a straight vertical line without some kind of horizontal run.
Old 11-11-2015, 09:27 AM   #24
Rewards Points: 16
Maybe AAV under sink?
The Following User Says Thank You to ragart For This Useful Post:
Ghostmaker (11-11-2015)
Old 11-11-2015, 01:14 PM   #25
Yep place it 4 inches above the trap...
Old 11-11-2015, 01:18 PM   #26
Rewards Points: 16
Thx. How urgent do you think from 1-5 with 5 being do it right away? Also proper to just cap the old vent pipe on the roof?
Old 11-11-2015, 04:28 PM   #27
Just leave the old vent alone isn't hurting nothing. Do it as soon as you have the time.
Sistering to correct warped joist... fprawlings4 Building & Construction 2 03-12-2013 08:04 PM
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 10:33 PM
How to Sister I Joist datahoe Building & Construction 18 12-31-2012 06:53 AM
Cracks in joist clydesdale Building & Construction 4 01-04-2011 08:08 AM
sister a joist Jack Hass Carpentry 7 06-19-2007 05:39 PM
