Joining PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2015, 11:19 AM   #1
Rewards Points: 63
Joining PVC
I'm trying to install a short section of 4" PVC to connect two existing sections end to end. Neither existing section can be moved to adjust for length, as they're underground. What is the best way to do this? What kind of couplings should I use?
Thanks in advance
Koldhammer is offline   Reply With Quote
Old 10-27-2015, 12:16 PM   #2
Civil Engineer
Rewards Points: 5,246
You can use a Fernco coupling, make sure you get the correct size, might have to go to a plumbing store for 4 inch.
Old 10-27-2015, 12:20 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,874
Thay also make a hard sleeve coupling... but you will need a plumbing specialty dealer/store.
MTN REMODEL LLC is offline   Reply With Quote
Old 10-27-2015, 12:52 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,266
Ayuh,.... That's what I'd use,....
Slip 'em onto the existin' pipes, drop in the new piece, 'n slide the ferncos into position, 'n tighten 'em down,....
Old 10-27-2015, 03:57 PM   #5
Rewards Points: 18,988
2, 4" PVC repair coupling will also work if you can find them.
Just a regular coupling with no hub in the middle so it can be slid over the pipe.
Joining an I beam pcousin1 Building & Construction 14 07-03-2012 07:05 AM
Concrete Joining hitesh deka New Member Introductions 2 08-20-2011 06:59 PM
joining wood chris in zante Carpentry 2 01-27-2011 04:18 PM
Joining wainscot at a 45 degree? MikeVila Carpentry 5 04-13-2009 09:30 PM
Joining cpvc to copper? randalg Plumbing 5 12-03-2006 07:42 AM
