Jet Pump -- Noise Control - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2016, 10:43 PM   #1
Rewards Points: 4
Jet pump -- noise control
We have a jet pump for our water system in the basement and it's pretty loud (despite being new -- less than 1 year old). Any ideas on ways to reduce the sound? I've read about some people using box enclosures to help...does that actually help?
Thanks!
jamminerun is offline   Reply With Quote
Old 01-02-2016, 04:08 PM   #2
Rewards Points: 114
I'm not really knowledgeable on wells but I have had insulated boxes built around pressure booster pumps. Be sure to check and make sure you can enclose the pump you have without overheating it. Also, has it always been noisy or is the noise new? If it's new you have another issue to look into.
2x_Tom is offline   Reply With Quote
Old 01-02-2016, 05:41 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,.... I'd think an insulated box would help,....
It's gotta be vented though,...
Puttin' a rubber mat under the pump might help too,...
Say a doubled up or tripled truck mudflap,....
Is the pipin' metal, or plastic,..??
Goin' to a submersible pump will fix it for sure,....
Bondo is online now   Reply With Quote
Pump Control test Franklin wkosbob Electrical 96 03-22-2017 04:30 PM
Had a close call with my well pump today ! Arky217 Plumbing 1 11-07-2015 12:32 AM
test three phase well pump and control box mcjkmike Plumbing 0 05-24-2011 08:50 AM
1hp control box on 3/4 hp well pump schunter Plumbing 2 04-28-2011 10:46 PM
Re: Pump Control test Franklin msenkpiel Electrical 1 08-04-2010 07:22 AM
