Irrigation Pump Connections - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2016, 11:42 AM   #1
Rewards Points: 321
The image shows my irrigation pump connections. I like that the pump is not "glued in." For the purposes of replacing the pump, the threaded fittings make it easier for maintenance. This worked for about a year but then the pump began sucking air.
I'm looking for advice on a possible solution to allow for pump maintenance without having to cut pipe and reglue fittings. I did not choose the location for the pump. Let's just say I inherited it.
I don't believe there are any leaks in the suction pipe below the fitting as when I disconnect the fittings, there is water at the top of the suction side and it doesn't go down.
The fittings I have in place now I think are the problem.
Thanks in advance.
CosmicMiami is offline   Reply With Quote
Circulator pump: guilty or not guilty? alight9010 HVAC 15 12-28-2015 08:43 PM
Question about piping for a well pump ktkelly Plumbing 6 04-23-2015 11:23 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
irrigation pump irrigant Electrical 8 04-24-2008 12:39 PM
