Iron And Sediment Filter Backwash Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2016, 06:43 AM   #1
Rewards Points: 2
Iron and Sediment Filter Backwash Plumbing
Hello,
I was wondering if anyone has an idea if it is ok to discharge an iron and sediment filter to the outside in TN?
I bought this house that had a pvc pipe that piped outside to a ravine, looks like they had a sink at one time in the laundry room.
This house had no filtration system at all before I put the filters in, very high iron.
So, I though it would be a good place to put the filters and put the discharge lines down the drain, air gapped of course.
Now I am selling the house and was wondering if that is going to throw a red flag upon inspection?
I have seen posts about water softener discharge back into septic with no problems, but nothing about iron or sediment filters.
Any help would be appreciated. Thanks
Jeff4040 is offline   Reply With Quote
Old 09-19-2016, 11:27 AM   #2
SHEPLMBR's Avatar
Rewards Points: 178
Re: Iron and Sediment Filter Backwash Plumbing
Not even softeners should be dumping into septic when backwashing. One it overloads the field, two it messes up the good bacteria in tanks and also displaces the sludge. That in effect could clog the drain field
SHEPLMBR is offline   Reply With Quote
Need whole house filter advice BRO931 Plumbing 7 10-04-2013 03:16 PM
Need Help Figuring Out Proper Filtration Setup HiccaBurp Plumbing 8 05-08-2012 01:28 PM
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 10:26 AM
Opinions on sediment filters? Mrdippy Plumbing 0 06-02-2011 07:49 PM
Water Softener Resin Bed Clogging with Sediment? batman71 Plumbing 2 02-23-2011 11:38 AM
