Installing A Shower From Unused Laundry Hookup - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2015, 06:19 PM   #1
Installing a shower from unused laundry hookup
We have a basement bathroom that has a tub with no shower. The wall that I am thinking of installing the shower on is unfinished on the other side (it was once a garage). There is an unused laundry hookup nearby on the unfinished side. Would it be fairly simple to route the hot and cold water from the laundry hookup through the wall and then attach the shower head and control on the other side? After spending the holidays trying to juggle showers for 4 adults with one shower, I'm ready to take matters into my own hands!
Vineta77 is offline   Reply With Quote
Old 12-31-2015, 07:20 PM   #2
Rewards Points: 114
Need a lot more information. It could be easy it could be a nightmare. It's probably not to bad to get the waters over. How are you planning on doing the drain? Are you going to do a full bath or just a shower?
2x_Tom is offline   Reply With Quote
Old 12-31-2015, 07:35 PM   #3
There's already a tub there, so no need to do any drains. It would just be installing a shower head from the laundry hookup rather than try to tie in to the existing tub water lines.
Old 12-31-2015, 07:42 PM   #4
Rewards Points: 582
pictures would help us...may be much eaiser to tap tub supply lines..and maybe it was set for shower but capped off????
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (12-31-2015)
Old 12-31-2015, 07:56 PM   #5
Here are photos of the finished side and unfinished side of the bathroom wall. I would take down the ugly blue tile and towel racks, and install the shower head and controls on that wall, then retile to the ceiling. The washer and dryer hookup is off by about a foot or so from where I'd like to install the shower head.
Old 12-31-2015, 08:00 PM   #6
Rewards Points: 582
yep go for it....but remember that set up you have is not designed for a shower... it will collect a lot of water ...
Vineta77 (12-31-2015)
Old 12-31-2015, 08:02 PM   #7
What would be the problem with installing a shower? I know putting a shower in a jetted tub is a little weird, but it wouldn't be used very often, just when guests stay and we all need to take showers in the morning.
If I install a full oval shower curtain around the tub to prevent water from pooling on top of the horizontal tile surfaces, I'm hoping it will help.
Old 12-31-2015, 08:03 PM   #8
Retired Moderator
Rewards Points: 7,174
Your tub is a deck mount---which will be a big leaker when shower water lands on the deck and goes under the lip of the tub---
If you do add that new shower mixer you will need a circular shower curtain ring to keep the water confined to the tub.
--NOW---to your question
Yep, tap into the waterlines from the laundry room---by far the easiest way to pipe that, in my estimation.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (12-31-2015), Vineta77 (12-31-2015)
Old 12-31-2015, 08:07 PM   #9
Property Mgt/Maint
Rewards Points: 8,202
you will have water splashing all over out side the raised tub lip. Where will that water go?
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 12-31-2015, 08:09 PM   #10
Thanks so much! Glad to see that at least we have that as an option!
The Following User Says Thank You to Vineta77 For This Useful Post:
Old 12-31-2015, 09:34 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Just add a diverter valve and a shower arm to the existing tub valve.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 12-31-2015, 11:07 PM   #12
Rewards Points: 114
I was thinking laundry tub. I was picturing somthing completly differsnt lol. That will work. You just have to find a way to keep water off the deck and keep it looking decent.
Old 01-01-2016, 05:03 AM   #13
Rewards Points: 127
Not only do need to keep the water off the deck,you need to keep of the walls as well. A circular shower rod around the tub will help with that.
Of course the cheap way is do like we do when visiting our families with one bathrooms , stagger the showers and those who need to spend half an hour primping after the shower, do it in some room other than the bathroom. Works well for our family.
jimn01 is offline   Reply With Quote
Old 01-01-2016, 05:46 AM   #14
Property Mgt/Maint
Personally I would trade you my extra shower, that no one uses, for a whirlpool tub any day of the week. And maybe just add a hand wand.
Installing a curved shower bar miamicuse Building & Construction 6 10-02-2015 06:34 AM
Installing new shower handle after retile xelaw Plumbing 21 08-09-2012 11:33 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Installing a Shower Blaze25 Plumbing 2 10-13-2008 07:32 PM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 08:26 AM
