Installing Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2015, 07:08 PM   #1
Rewards Points: 374
Installing kitchen sink
I would like to install a kitchen sink and couple of cabinets to convert this area into a wet bar.
Question is to which wall ?
On the other side of the counter top wall is a bathroom sink. Installing the sink to the shared wall (by removing the current counter top) is easy since the drain line is right behind the wall. Installing the sink underneath the window wall (external wall) involves more work hence expensive.
I heard that kitchen sinks should be installed underneath the window. Is that right ? Should I installing the kitchen sink underneath the window if it is going to expensive. Please suggest.
cprao is offline   Reply With Quote
Old 11-06-2015, 07:49 AM   #2
Rewards Points: 76
It's just a wet bar, not a full kitchen. Install the sink wherever it will you want it.
ponch37300 is offline   Reply With Quote
The Following User Says Thank You to ponch37300 For This Useful Post:
SeniorSitizen (11-06-2015)
Old 11-06-2015, 08:05 AM   #3
Rewards Points: 127
The only reason for putting a kitchen sink under a window is appearance and it makes for a slightly more enjoyable dishwashing experience looking out in the yard as opposed to a blank wall. Other than that no reason. Put the bar and sink where you already have the plumbing
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
Old 11-06-2015, 08:55 AM   #4
Rewards Points: 374
Thank you. This clarification helps.
The Following User Says Thank You to cprao For This Useful Post:
Kitchen Sink "Too Big" randnday Kitchen & Bath Remodeling 20 08-21-2015 04:16 PM
Kitchen sink plumbing question Lin171 Plumbing 30 07-19-2015 06:29 AM
Undermount kitchen sink gunk build-up Mike in Brier Plumbing 4 04-29-2015 06:34 PM
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Resetting Undermount Kitchen Sink Voss Plumbing 0 02-24-2012 12:47 PM
