Installing Gas Line For BBQ - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By SeniorSitizen
  • 1 Post By lenaitch
Old 01-27-2017, 11:58 PM   #1
Rewards Points: 125
Installing gas line for BBQ
In my front yard, there is a pipe protruding from the house wall about 1" with a cap screwed on to it. I'm not sure what it is, but I'm guessing gas, because it's right next to a small brick layout on the ground, which seems like a natural spot for a BBQ grill. The pipe is slightly rusted, but I think it's galvanized. There is no valve.
My plan is to shut off the gas at the main valve where it enters the house. Then remove the cap and turn the gas back on slowly to smell if that's what it is. Assuming it is gas, I'll add a shutoff valve, a reducer, and a quick-connect valve to hookup a BBQ grill.
Does this sound like a good plan?
llamafilm is offline   Reply With Quote
Old 01-28-2017, 07:57 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,240
Re: Installing gas line for BBQ
Ayuh,..... I'd guess a 1" pipe is water,....
Gas lines, especially for a BBQ would be somewhat smaller,...
Donno,....
Old 01-28-2017, 09:48 AM   #3
Rewards Points: 6,378
Playing the odds, being it's in the front yard I have my doubts about it being for a BBQ grill since they're most often in the back yard. And if you only close the gas supply and it happens to be water you may get real wet.
Proceed with caution.
There is another way it could be checked for gas or water without removing the cap but I won't suggest that here.
Old 01-28-2017, 10:28 AM   #4
Rewards Points: 462
Also turn off the water.
Justin_99 is offline   Reply With Quote
Old 01-28-2017, 10:00 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 2,050
It could be anything: gas, water, somebodies homemade electrical conduit, a tie-up for the dog. If you have a basement, what's at the inside of the foundation wall. Be it gas or water, it's gotta come from somewhere. I agree that it seems unusual for a bbq hookup to be in the front yard and that 1" is a lot for a single appliance line.
lenaitch is offline   Reply With Quote
Old 01-28-2017, 11:31 PM   #6
Rewards Points: 80
It does sound a bit on the large side. However, if you have low pressure supply, and the previous owner had a very large appliance, it's possible.
I agree with those above.
Cheers!
supers05 is offline   Reply With Quote
Old 01-29-2017, 01:05 AM   #7
QUOTE: a pipe protruding from the house wall about 1" .
Plenty easy to misinterpret as a 1" line.
supers05 likes this.
Old 01-29-2017, 10:18 PM   #8
Usually Confused
lenaitch's Avatar
Yup, and that's exactly what I did.
Old 01-30-2017, 08:58 PM   #9
Rewards Points: 80
Yup....... Lol
Cheers!
Installing a gas line, pre-planning ignition Plumbing 1 02-28-2010 05:01 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
Installing a Gas Line for a Jen-Aire.... LAHKATY Remodeling 3 11-19-2009 07:58 PM
Any tips or tricks on installing a line set ? tuckerz HVAC 10 11-04-2009 06:24 AM
