Installing A Basement Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2015, 09:51 AM   #1
Rewards Points: 20
Installing a basement shower drain
I'm installing a shower in my basement and just wanted to make sure it was ok to tie into the same drain the sink uses. It's also used as a wet vent for the toilet and sink too. its a 2" pipe under the cement and I'll be installing a 2" drain from the shower to this with a Y-pipe.
The shower is within 5 feet of this drain/wet vent so I won't have to add a vent to the shower directly correct?.
vanilla-thunder is offline   Reply With Quote
Old 12-14-2015, 05:40 PM   #2
Rewards Points: 1,854
As long as it's two inch and your less then 8 foot from your tie in.
Old 12-14-2015, 06:19 PM   #3
Rewards Points: 20
Excellent! Thanks
Basement shower into open floor drain question kwasley Plumbing 7 10-24-2015 06:06 AM
tapping into basement tub drain muellertr Plumbing 11 02-07-2013 01:38 PM
Lowering basement slab and installing drain tile diybrad Concrete, Stone & Masonry 0 04-26-2012 09:36 AM
Installing Shower in basement jburchill Plumbing 5 05-05-2011 12:14 PM
Basement shower drain help.. helpless handyman Plumbing 79 02-26-2008 09:39 PM
