Installed Water Heater But.... - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2016, 05:09 PM   #1
Rewards Points: 1,128
Installed water heater but....
Some of the soldered joints are leaking...:rage::rage::rage:. Took 5 hours now this. Maybe I shouldn't have soldered when connected together amd trying to work above water heater. It was very hard to get under and the back of some pipes. Then when I turned the water on and saw some leaks I turned water off and wiped dry but then the solder wouldn't stick to pipe. I'm so angry and disappointed. I was actually proud I did everything up to that point now this. Any advise? Have no hot water....for now. Thanks a lot. Thanks .
Mstrlucky74 is offline   Reply With Quote
Old 02-14-2016, 05:34 PM   #2
Rewards Points: 3,230
Good for you mrstlucky. It's a good feeling when you diy.
Sorry to hear about your issues though. Could be a couple things.
With solder not sticking, may be you are not using enough flux, not prepping the copper pipe enough, not letting the bead of solder go around fitting, heating incorrectly, etc.
Try working with a pipe and couple fittings on a bench first till you get it right or use sharkbytes.
jmon is offline   Reply With Quote
Old 02-14-2016, 05:37 PM   #3
Rewards Points: 469
Pictures, Soldering water lines with any water left in them is very hard to do, The water flashes to steam and will cause your solder joint to leak I always install a shutoff to hold water back or a union that I can leave open to let the steam escape. At this point its best to cut it all out and start over
Jnaas2 is offline   Reply With Quote
Old 02-14-2016, 06:16 PM   #4
Thanks so much guys. Yes it really was a great feeling until that. Yes I may cut it out and go with shark bites..lol. Are the shark bites any good? How could they be better than a solders joint. Thanks
The Following User Says Thank You to Mstrlucky74 For This Useful Post:
jmon (02-14-2016)
Old 02-14-2016, 06:26 PM   #5
Ah .. Now you took all the fun and learning experince out of it. Lol..
Hope you get it up and running soon mstrlucky. Let us know how everything works out for you. Thanks.
Old 02-14-2016, 08:12 PM   #6
Lol jmon. So my buddy is gonna come by tomorrow and help. He agrees we should cut it out and start again but he thinks we should solder and not shark bite.
The Following 2 Users Say Thank You to Mstrlucky74 For This Useful Post:
jmon (02-14-2016), oh'mike (02-15-2016)
Old 02-14-2016, 08:21 PM   #7
Now that's the spirit of a diyer...whooaa..
Old 02-14-2016, 08:57 PM   #8
Rewards Points: 426
I've had better luck using Mapp gas for pipe above 1/2" ...white bread trick has saved the day more than once also.
Damp rag to wipe the joint after soldering , spray water bottle so you don't catch something on fire.
the handyman's secret weapon, duct tape
High Gear is offline   Reply With Quote
Old 02-14-2016, 09:28 PM   #9
WhatRnsdownhill's Avatar
Rewards Points: 2,220
you could always just open the relief valve...
WhatRnsdownhill is offline   Reply With Quote
Old 02-14-2016, 09:29 PM   #10
thats why professionals get paid good money to install waterheaters and boilers..
Old 02-15-2016, 04:08 PM   #11
The first time I ever soldered I had a bunch of leaks. I watched a few videos on it and cut it all out and redid it and I didn't have any leaks the second time. I learned a lot in a short time. Practice helps for sure.
Plumbvoltage is offline   Reply With Quote
The Following User Says Thank You to Plumbvoltage For This Useful Post:
Old 02-15-2016, 04:46 PM   #12
I'm going to do that. I have another water heater for my tenants that will need replacing soon.
Old 02-15-2016, 05:25 PM   #13
Retired Moderator
Rewards Points: 7,174
What flux did you use?
Did you use MAPP or propane?
What solder?
Old 02-15-2016, 05:36 PM   #14
Originally Posted by oh'mike
What flux did you use? Did you use MAPP or propane? What solder?
I used mapp. Not sure of flux or solder type....they're in my shed now. Friend came over and fixed everything.
Watched some video and I feel confident now. I was putting the flame directly on the solder many times. I also didn't know that for 1/4" pipe you only need about 1/4" of solder. Also ....solder is drawn toward the flame/heat.
jmon (02-15-2016)
Old 02-15-2016, 05:55 PM   #15
Retired Moderator
Next time--heat from the back--touch solder to the front--when it melts--it will draw all the way around---
jmon (02-15-2016)
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
