Install Utility Sink Into Current Washer Standpipe/vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2016, 10:42 AM   #1
Rewards Points: 2
Install Utility Sink into current washer standpipe/vent
I am looking to find a solution to the correct way that I can plumb this utility sink into my current washer standpipe/vent. I live in Maryland.
I have a attached a picture of the current setup. Standpipe on right going to drain/vent. I would like to bring in the sink from the left side of the set up. Can I replace the san tee with a double san tee and have the sink and washer share the same vent since they are draining at the same level? Or will I have to vent the sink side along its horizontal run and run a vent up and over to the current vent?
The sink will also be in my garage which is 18" below the laundry room so I will have a utility pump pumping the water up to the drain.
Any feedback is appreciated.
Install Utility Sink into current washer standpipe/vent-img_3649.jpg
Bosker27 is offline   Reply With Quote
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
Easiest way to install utility sink for washer to drain into? iammikeDOTorg Plumbing 9 02-09-2014 04:19 PM
Deep sink install in garage with existing washer dryer connection contrix Plumbing 2 11-22-2013 10:11 AM
Farmhouse sink install question Master Brian Remodeling 1 10-22-2013 02:43 AM
washer drain into utility sink john_bry Plumbing 2 11-21-2012 04:23 AM
