Instaling Shower Base And Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2015, 07:25 PM   #31
Rewards Points: 26
To be clear there is concrete under the tile.
kc_fella is offline   Reply With Quote
Old 03-05-2015, 10:17 PM   #32
Rewards Points: 26
Made it down an inch but have another in h to go. Painful...
Old 03-06-2015, 05:48 AM   #33
Rewards Points: 1,952
This is an example of why a 3 by 4 90 should be used for a toilet stub. You can glue a 3 inch flange into the 4 inch stub.
Old 03-06-2015, 06:20 AM   #34
Rewards Points: 26
Yes that would have been nice. Given my current situation should I keep progressing as is? Also could I cut my flange down a bit?
Old 03-06-2015, 02:08 PM   #35
As full you make the joint the better job you have. I would cut your pipe down a bit so you get more angles with a chisel. Stuff some rags in it for chips.
Old 03-07-2015, 11:24 AM   #36
Rewards Points: 26
Help! Now I really messed up. Not sure if I hit it with the chisel or the hammer drill but I have a dime sized hole about 1.5 inches below the finished floor! Options?
Old 03-07-2015, 12:48 PM   #37
Rewards Points: 2,528
The hub of the closet flange will cover more than 1.5" of the pipe.
hammerlane is offline   Reply With Quote
Old 03-07-2015, 01:21 PM   #38
Also if you need to cut the pipe to below grade, buy one of these for $11 at one of the box store
Old 03-07-2015, 01:37 PM   #39
Rewards Points: 26
The flange I had bought is 2". Do you think the half inch is enough past my error hole?
Shower Drain 325_man Plumbing 9 06-12-2014 06:34 AM
Moving Bathtub Drain for Shower Base 325_man Plumbing 4 04-25-2014 08:24 AM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Drain for preformed shower base svaic00 Plumbing 1 05-02-2013 10:11 PM
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 09:02 AM
