Indirect Tank Plumbed Backwards - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By rjniles
Old 06-21-2016, 11:45 PM   #1
Rewards Points: 416
Indirect tank plumbed backwards
I had a new boiler and indirect water tank installed about 6 months ago. I just noticed the tank has stickers saying "To boiler supply" and "To boiler return" and tracing the pipes back to the boiler they're piped backwards.
How much efficiency is lost this way, or why is the hottest output from the boiler supposed to enter the higher port on the tank and coolest exit the bottom?
Piedmont is offline   Reply With Quote
Old 06-22-2016, 05:15 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 812
Re: Indirect tank plumbed backwards
Hot water is drawn from the top of the tank, so that is the portion you want the hottest.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 06-22-2016, 07:43 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,700
Normal tanks the hot water is drawn from the bottom and cold enters the top.
Old 06-22-2016, 08:00 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 812
Not in any water heater I have ever seen. It would defy the laws of physics: Hot water rises.
joed and Piobguy like this.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Javiles (06-26-2016), joed (06-22-2016)
Old 06-22-2016, 08:27 AM   #5
Rewards Points: 416
Let me clarify, I'm only referring to the indirect part. Here's a picture better explaining it. The domestic hot/cold are fine it's the plumbing to the boiler. Here's an image to show how it was piped, which is opposite to the instructions & stickers on the tank, and every indirect water heater instructions I've seen. It works, I just don't know the effects or how things are better if plumbed the other way as the instructions on the tank say.
Old 06-22-2016, 09:02 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 812
I understood your original question. Since the hottest water is at the top of the tank, you want the hot source from the boiler closest to the top of the tank. That being said I am not sure if in an indirect heating application that it would make a great deal of difference. But since you paid to have it installed I would want it corrected.
Old 06-22-2016, 05:11 PM   #7
Super Moderator
joed's Avatar
Your right. I got that wrong. The cold water goes in the dip tube to the bottom.
Pressure tank problem? Or something else? d189379 Plumbing 3 05-06-2016 03:19 PM
Tempering Tank jagans Plumbing 16 06-05-2013 09:58 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 06:43 AM
hot water tank help needed psp Plumbing 2 08-22-2010 02:46 PM
